Results 1 to 7 of 7
Thread: Need to install two new toilets, back to back issue
Hybrid View
    DIY Junior Member BruceG's Avatar
    Dec 2010
    San Jose CA
    Default Need to install two new toilets, back to back issue
    We are doing a remodel and will replace two older Toto toilets. They are back to back connected with a "T". I was going to install newer Toto toilets but due to our "T" connection Toto won't support it. I researched American Standard and Kohler and their support reps have said the same thing - they won't perform in a back to back with a "T". Our plumber has told us that to change out the T would be a substantial amount of work (and cost).
    I've seen some postings in this forum that indicate that while it's not ideal, it can be done with some possible issues.
    Two questions:
    Realistically, what type of issues could we expect?
    Second, which brand/model would best the least problematic in this config? We do need ADA height, and would like to stick with a major brand where replacement parts won't be a problem down the road. We'd like to keep the price reasonable, but do want decent quality.
    One suggestion was a Kohler model with their Ingenium flushing system but from what I can read that's not an especially good toilet - hate to install something I know in advance won't work well.
    Thanks in advance for any help.
    Bruce
    To flush with the mandated smaller water use, ANY toilet needs to flush much faster than the old styles. I don't think any of them will work properly with a simple T between them. What will happen is the jet of water created when they flush will flow across and cause splashing in the other toilet, not a good situation, especially if you're sitting there! time to bite the bullet and change it out to the specified fitting.
    Dec 2010
    San Jose CA
    Jim,
    Thanks for your feedback. The cost to make the change is steep as it involves a lot of redoing of the piping - it's not a simple switch of the connection unfortunately.
    We can certainly ensure we don't use both toilet at the same time to avoid any issues - if that's the only problem we'll live with it. I'm interested to know if that's the extent of the problem, and if there are any toilets currently that might be less prone to cause a problem. One that might not be as powerful as the new Toto for example, but would do a better job than the Kohler with the known issues.
    Thanks,
    Bruce
    Yakima WA
    Agreed that making the drain configured correctly may be costly, that's the only option you have. Please realize that changing from Toto toilets to any other brand will not fix the problem. This might be a time that a plumber would offer the most cost effective solution in the long run. He would not only do it right, but probably would have it completed in the time it would take you to figure out how to DIY.
    Any toilet with a 3" or larger flush valve will push some water from the opposing toilet bowl.
    Using a slower flushing 2" flush valve will mitigate the issue.
    That being said, I do plenty of installs on back to back toilets, and yes you can lose some water in the opposing bowl. It's not that big a deal.
    However, my new installations are being piped with that in mind. Rough In plumbers, are you reading this?
    A double wye fitting on the left is okay
    A double fixture fitting is marginal, it will still lose water in the bowls.
    A double Santee on the right doesn't not work well at all.
    Dec 2010
    San Jose CA
    Terry - thanks for the input. So where were you when they built this house in 1973?
    Would you have a recommendation for the "best" 2" toilet to look at? By the way, this is part of a remodel, not a DIY job. If completely necessary we'd have the plumber make the changes, but he's told us that it's not simple (or cheap) and I have good confidence in him - he's experienced and has done a good job for us.
    Bruce
  1. Adding bathroom back to back with existing - share 3 inch branch?
    By mturse in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-04-2008, 07:25 AM
  2. Back to back toilets
    By JimBt in forum Toilet Forum discussions
    Last Post: 10-03-2008, 04:56 PM
  3. back to back toilets
    By se215 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-05-2008, 03:35 PM
  4. wye fitting with back to back toilets
    By truthseekerz in forum Toilet Forum discussions
    Last Post: 05-03-2008, 04:45 PM
  5. back to back toilets
    By dallas homeowner in forum Toilet Forum discussions
    Last Post: 07-10-2006, 09:21 AM
