Thread: no water from hot taps
    DIY Junior Member mobile home dweller's Avatar
    Dec 2010
    Waxhaw NC
    Default no water from hot taps
    I have no water coming from hot side. cold side ok. had problem the other night. ran cold water for a while, heard "bump", then hot water flowed. i've heard the bump before, in the morning when turning on the shower. flow (hot) would be strong for one second then back off, bump, then normal. what's wrong with my system? Any help is appreciated.
    In the trades Dana's Avatar
    Jan 2009
    What type/make/model hot water heater do you have?
    Does the hot water stop at all valves, or only some? If you go to the WH and open the T&P valve, do you get water out? Many WH have heat traps on them, if they are installed on the wrong port or backwards, flow can force them closed. There could be crud in the line and when flow occurs, it moves to a point where it stops the flow.
  1. Hot and warm water taps instead of hot and cold for washer?
    By Linda49 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-13-2010, 07:24 AM
  2. Hot water out of cold taps - plumber is stumped
    By Bustergordon in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-06-2010, 01:39 PM
  3. very hot water as soon as taps turned on
    By chinto in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-10-2009, 07:21 PM
  4. No water From Hot Taps
    By indesec in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-03-2005, 08:35 PM
  5. air spluttering and spitting from hot water taps
    By Mike_J in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-02-2005, 08:17 AM
