thegallery
I just replaced two tap stems in one bath and figured a separate shower facet in an adjacent bath would be the same. I figured wrong!
So I go to take out the whole stem but when I try turning the large brass nut at the back it doesn't move? I put a lot of force with a pipe wrench on it but no luck, and I'm frightened to try to force it because I'm not sure it does move?
The tap itself is not leaking but both taps are letting water run into the shower head and drip. It slowly got harder and harder to turn off and now you can't turn it off completely.
I think I remember a way of just replacing the inner part but even with those the inner retaining bolt easily comes off but the turning rod does not? Plus being that they are 50 years old I kinda just want to replace the whole stem.
Any ideas?
Any ideas?
