Results 1 to 5 of 5
Thread: pvc pump well head
    DIY Junior Member byteman's Avatar
    Nov 2010
    South Carolina
    Default pvc pump well head
    Hello, I want to pull my 140 foot sub up but the cap seems to be glued on. Is this possible?
    If the casing and the cap is PVC, yes. Beat on it with a hammer or 2 x 4 to try to get it off, and if it doesn't come off, get a saw and cut it off just below the bottom edge of the cap. The nbuy a regualr cap for the OD of the casing. They are held on with bolts. Or use a sanitary seal for the ID of the casing.
    Well Drilling/Service justwater's Avatar
    May 2010
    NE FL, SE GA
    so there is just a regular slip (glue style) cap on well casing with 2 holes drilled in it.. one for pump line and one for wire? remember someone needs to be pulling up on the pump line (should move freely if its just going through a drilled hole in the cap and is sitting on a coupling or 90 degree fitting) while another person taps up on the cap... or else you're trying to tap the cap up against the weight of the pump. if it was done like this and the cap is glued on, whoever installed this was a real pinhead. i've seen pumps installed like this before, but the installers were smart enough not to glue the cap so you could pull up on the pump line and tap it off. and i agree, i'd feel better putting it back in using a well seal.
    Quote Originally Posted by justwater View Post
    That's only for a well with no pitless adapter but, if the water line/drop pipe was visible, I believe anyone wanting to pull their submersible pump would lift the pipe to get the cap off instead of lifting the cap to pull the pump as he said he wants to.
    And since he didn't mention any water line through the cap, my money is on him having a pitless adapter and no water line or electric line through this casing cap.
    Nov 2010
    Maine
    I don't know why some drillers are compelled to glue the cap on. Maybe to save a few bucks or perhaps to insure a callback when something goes wrong.
    Gbyall
  1. Low head pump
    By tkeoki in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-14-2009, 02:19 PM
  2. Well head hissing when pump is on??
    By Rutherfordman in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-13-2009, 10:38 AM
  3. shallow well-pump to well head distance
    By rreynaert in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-22-2009, 10:33 AM
  4. Dead Head pump dry running
    By Bob1000 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-01-2007, 05:48 AM
  5. Jet pump head busted.
    By caktus in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-13-2006, 07:14 AM
