CapstanRec
I'm having a recurring problem with a galvanized lav drain...
About a year ago my upstairs lavatory drain was draining slowly. I borrowed a friends manual 25' snake and with some patience I was able to clear it. I could run the water full blast with no backing up. But slowly over time the problem came back. It would back up into the lav, but within 15-20 seconds the lav was empty. Not really a big deal.
My roomate asked if he should plunge it... I said DO NOT plunge the sink. I left for Thanksgiving to visit some family, and when I got back he said he plunged the hell out of the sink and now it's totally clogged. It does not drain... water stayed for hours until I removed the p-trap.
I called a plumber and he worked on the drain for a half hour or so. He said even with the smallest bit (1/4") he couldn't get through a 90 in the wall... about 8' in. He said "This is some old stuff" and the galvanized is probably rusting (or rusted) shut. Apparently the drain stub takes a 90 right then takes another 90 left to a vertical piece of cast iron. The problem is at the second 90.
Any suggestions or insight? Did my roomate plunging form a huge slug?
I'm going to try my manual snake again this evening after work... I remember it took me a while to get through the clog last time.
