Results 1 to 7 of 7
Thread: Toto Aquia - keeps running as though tank is still filling
    DIY Junior Member metropxp's Avatar
    May 2009
    New Jersey
    Default Toto Aquia - keeps running as though tank is still filling
    We have the dual flush and have been happy with it. Every year or so I get some noise after filling and replace the cap and move on. Recently, however, the one in the master bath sounds like it keeps running.
    The odd thing is if you flush the toilet in the main bath or turn on the water in either of the bathrooms, the running water at the toilet stops for a few minutes.
    Any ideas as to what's going on? Incidentally, my profile lists me as "DIY Junior Member." It really should be "Knows Enough to be Dangerous!
    In the interest of full disclosure we have town water, but it comes from an artesian well (or so I'm told). As a result, the previous home owners installed a water softener which we still maintain. We did have to replace a couple of faucets when we first moved in due to hard water stains/buildup.
    I didn't know if the softener salts could affect the workings of the Toto Aquia.
    JT
    Dec 2007
    Is the water level in the tank filling to the proper level then shutting off properly?
    Is the water in the tank then draining into the bowl through a leaking flush valve and when it drains down enough the fill valve turns on and refills the tank to the proper level.
    This can be verified by die testing with food coloring, if the color gets into the bowl without flushing it is leaking!
    In which case you need to service the flush valve.
    Here is the instruction manual.
    www.terrylove.com/korky
    If you replace the assemby cap, remember to remove the "flow reducer" and reuse it in the new cap.
    It's a little green sleeve that fits inside the fill port on the cap.
    May 2009
    New Jersey
    Terry, I'm confused:
    "If you replace the assembly cap, remember to remove the "flow reducer" and reuse it in the new cap. It's a little green sleeve that fits inside the fill port on the cap."
    Is the assembly cap the same as the Quiet Fill replacement cap? If so, what is the "flow reducer?" I've never removed it before.
    May 2009
    New Jersey
    Never mind. Long story short...I got a bad cap. "It couldn't be the cap, I just replaced it." New one seems to be doing the trick.
    Although I am still curious about the "flow reducer." What is it and where do I find it within the mechanism?
    Apr 2007
    Ontario, Canada
    Quote Originally Posted by metropxp View Post
    On the cap where the refill tube connects to has a green insert in it for the Aquia the regular cap does not.
    May 2009
    New Jersey
    CURSES...Foiled again. Toilet is running again even with the new cap. A few questions, but first thank you to all the experts and DIY folks for sharing their knowledge.
    Now: 1) Do I NEED the flow reducer? This is about the third time I've swapped out the cap (once a year, basically) and never knew about the flow reducer. Could this be the root of problems?
    2) Exactly how does the float work on this Quiet Fill valve when it come to stopping the water flow? The way the toilet is running right now, if I had an old fashioned mechanism I would just adjust the float arm. On this, since the float just clips onto the fill valve, what is it activating/affecting to stop the flow?
    The reason I ask is the tank fills, but the water still runs just a bit. You can see the water in bowl shaking a little bit. When take the cap off the fill valve and jiggle the float it stops for a moment, although if you lift it too high, it really makes the water flow.
    I was going to just replace the whole fill valve, but how do you get underneath the tank to disconnect it? The cowling on the bowl is so big I can barely fit my hand up there to reach the water supply. Do you need to remove the tank from the bowl?
  1. Toto is constantly filling, not quite sure how to fix
    By momof6 in forum Toilet Forum discussions
    Last Post: 06-08-2011, 12:21 PM
  2. Brine tank filling up with too much water
    By eldyfig in forum Water Softener Forum, problems, installation and reviews
    Last Post: 02-23-2011, 10:51 AM
  3. Toto Aquia - Water Dribbling Into Bowl from Tank
    By ryan92262 in forum Toilet Forum discussions
    Last Post: 08-15-2010, 10:38 AM
  4. Silently filling tank
    By tjacquer in forum Toilet Forum discussions
    Last Post: 03-16-2008, 06:24 AM
  5. Slow filling tank
    By Bob T in forum Toilet Forum discussions
    Last Post: 09-05-2005, 01:31 PM
