Results 1 to 1 of 1
Thread: Flexable Duct
    DIY Member jetlag's Avatar
    Dec 2009
    Ga.
    Default Flexable Duct
    Is it ok to use the silver flexible insulated duct between two foor levels where it will be concealed and unable to access . I plane to run two 10" metal ducts and come off of those with the flex for the floor registers . Does the 2 - 10 " main ducts sound about right for 600 sq ft and reduce down to 8" about half way . The two 10" with one down each side will work better than a large one down the center because I cant get much larger between the floor trusses.
  1. How much duct work fo I need
    By droemer in forum HVAC Heating & Cooling
    Last Post: 09-15-2008, 12:21 PM
  2. Duct sizing?
    By Nate R in forum HVAC Heating & Cooling
    Last Post: 03-13-2008, 06:08 PM
  3. 3" abs flexable?
    By cammok5 in forum Plumbing Forum Discussion & Blog
    Last Post: 01-04-2008, 08:43 PM
  4. flexable vent
    By Giles in forum Plumbing Forum Discussion & Blog
    Last Post: 08-30-2007, 08:44 PM
  5. Flexable Gas Line or Black steel
    By rp in forum Plumbing Forum Discussion & Blog
    Last Post: 12-23-2006, 09:06 PM
