Thread: Any hope of getting well water in clay soil?
    DIY Junior Member bigsmile's Avatar
    Nov 2010
    Mississippi
    Default Any hope of getting well water in clay soil?
    I just dig a shallow well down to a little over 15'. I hit water at close to 15 feet. I think I can dig 10' more without problem. But what concerns me is that the soil seems to be mostly really fine clay. Actually, when I dug down to 15' or so, I didn't even know that I hit water. I took a long rest and when I came back, I found water.
    So, is it still realistic to expect, say, 1 gpm or even a quart per minute from this well (when it's dug down to about 25')?
    By the way, the hole I dug is 6 ID.
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    Does this help?
    http://groundwater.ucdavis.edu/Publi...FWQFS_8086.pdf
    Here's a test you can run
    Well diameter= 0.5 foot
    Water depth= 15 feet
    Well water volume [V]= 22 gallons
    Well input/output [IO]= 1 GPM
    user demand [D, D>IO]= 2 GPM
    output duration [OD] = V/(D-IO)
    OD= 22 minutes
    output gallons [G] = OD x D
    G= 44 gallons
    Moderator valveman's Avatar
    Mar 2006
    Fill the hole with water from another source. If it won't take water, it won't make water.
  1. new well water cloudy...clay?
    By gorgemom in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-29-2008, 10:15 AM
  2. Clay roof tile - "Spanish clay"
    By kingsotall in forum Remodel Forum & Blog
    Last Post: 11-08-2008, 07:00 PM
  3. I hope I did this right
    By rworell in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-29-2008, 12:59 PM
  4. Clay Soil Pipe for an upstairs toilet
    By danmerk in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-07-2007, 02:21 PM
  5. brown hot water - clay
    By Crilou in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-28-2005, 05:38 AM
