Page 1 of 2 12 LastLast
Results 1 to 15 of 20
Thread: Is there a 200 amp breaker box with 100 amp main
    DIY Member rayh78's Avatar
    Sep 2008
    Virginia
    Default Is there a 200 amp breaker box with 100 amp main
    Have a remodel to do and will sub out electrical.
    Electrician I have used in the past said I cant do this.
    Years ago I had the same situation. Small house with 100 amp service and customer does not want to pay for upgrade now but wants breakers. Instead of putting in just a 100 amp breaker box, I had a 200 amp Murray box put in and install a 100 amp main breaker instead of a 200 amp main. The box was still 200 amp to make a future upgrade easier. A murray 100 amp breaker fit in the same space as a 200 amp for the Murray brand. Which was not the same with square D. Since then if ever I contracted out any electrical we have used square D brand. But have this situation again and they dont make murray anymore. Is there another brand out there?
    Electrician does not want to do this either. Use just a square D 200 amp box with a 100 amp square D line feed breaker because he saids maybe a problem with inspector.
    I'm by no means a pro, but it is my understanding that as long as the supply line capacity is not exceeded by the protection circuit, it is okay to use a smaller cb. Now, with more available slots, you are more likely to be able to trip the main breaker, but that's another issue. Logically, but maybe not by code, it should be in the same idea as using 12g wire on a 15A service, which could also use 14g. The wire size determines the maximum current that can be drawn.
    Jul 2007
    USA
    You need to convince the customer that they are mad.
    When I tried to do the opposite (upgrade the service but not the panel) the extra cost of calling out an electrician just to do the panel in the future would have been much more than the modest increment I ended up paying to get it all done in one go.
    Not to mention the requirement for another inspection.
    Refuse.
    Sep 2008
    Virginia
    Alittle more info.
    This is a small 600 sq.ft. guest house on a seperate meter and has gas heat.
    So it is questionable if an upgrade would ever be needed but they would like the option. And it would save some work. And the price difference between a 100 amp or 200 amp box is not that great.
    Would save morethan that if ever an upgrade
    Electrical Contractor Jim Port's Avatar
    Aug 2009
    Maryland
    I can see no logical reason to think about installing any more than a 100 amp panel for a 500 square foot house.
    What is feeding this panel? If it is a subpanel, just install the 200 amp unit with a 100 amp breaker at the main panel. if it is being metered, the electric company can install new cables and meter, or just a 200 amp meter if their wires are adequate.
    Dec 2009
    northfork, california
    600 sq feet with gas and 200 amps? Going to smelt aluminum?
    60 amps is plenty like every three bedroom house had until 1970...
    You can use a 100 amp panel and feed it with a 50 amp breaker, and I'll bet it NEVER trips.
    200 amps is absurd unless they plan to add 4 more 600' units to this one.
    Sep 2008
    Virginia
    still has electric hot water and stove and the long term possiablity was to switch to a heatpump
    Aug 2009
    Maryland
    If you switch to a heat pump stay with the gas for the backup heat.
    Dec 2009
    You could feed 200 amp sub panel with a 100 amp breaker but should size wire for the 200 amps.
    Goes without saying if this is for a future upgrade, otherwise the whole discussion is irrelevent.
    Sep 2008
    Virginia
    Would use the same wire for now. Just so I understand options.
    It would be against code to use 200 amp box. Blank off cover space for the factory main breaker and then use 100 amp line feed breaker.
    thanks
    You can use any panel you want, with or without the main breaker, as long as the breaker feeding it is appropriate for the wire to the panel. Although you might have a bit of difficulty attaching the wires to the buses without going through a main breaker.
    Aug 2009
    Maryland
    If you decide to backfeed the breaker you will need to install a breaker hold-down kit.
    DIY Member TWEAK's Avatar
    May 2009
    Bay Area CA
    Does the guest house have its own independant service entrance? Or is it a sub panel fed off the main house panel?
  1. Main breaker box clearance
    By ktambascio in forum Electrical Forum discussion & Blog
    Last Post: 07-01-2009, 06:12 PM
  2. Main Breaker Tripping
    By Dunbar Plumbing in forum Electrical Forum discussion & Blog
    Last Post: 01-08-2009, 03:39 PM
  3. PUMP can effect to main circuit breaker get trip?
    By chomnap in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-09-2008, 05:34 AM
  4. Main Circuit Breaker Panel Humms
    By edstevn in forum Electrical Forum discussion & Blog
    Last Post: 12-02-2008, 07:29 AM
  5. Sprinkler Air Vacuum breaker vs Pressure vacuum breaker
    By Mike Pascutiu in forum Irrigation / Sprinkler Forum
    Last Post: 05-28-2005, 01:47 AM
