Results 1 to 7 of 7
Thread: putting hot water into a pot filler (single valve)
    Nov 2005
    Default putting hot water into a pot filler (single valve)
    I'm wondering why pot filler faucets all are spec'd for Cold Water Only. I would like to run mixed water through one of these. I would add a mixer and forget about the single valve on the pot filler.
    Obviously I could contact all the manufacturers and ask them about running various temperatures through the potfiller, but...
    I'm hoping someone can shed some light on this question beforehand.
    What if anything could make it a bad idea for mixed water to be run through a spout sold as "For Cold Water Only".
    Mixed water might be quite hot at times, so a limit stop could be added too.
    The purpose of this effort is to have my very own remote-mixer wall-mount kitchen faucet.
    Jan 2006
    Rosedale, Md
    >>>I'm wondering why pot filler faucets all are spec'd for Cold Water Only. I would like to run mixed water through one of these. I would add a mixer and forget about the single valve on the pot filler.<<<
    I think it might be a safety thing, you don't supposed to drink hot water unless it is above 140deg which most waters are not set at
    Hot water items are made to withstand the high temps; cold water items are not.
    You should never ingest water heated in a water heater. The chemistry of the water is changed as it sits in a water heater and it's not for the better.
    Nov 2005
    Thank you !
    This makes it "official" ; it's the only reason anyone ever gives me. So, it's not a valve thing. Unless someone tells me otherwise.
    Next challenge is getting my woman to cooperate with NOT using hot water for topping up pots. She is a foreigner so some things take time to explain. Or, use an Instant Hot Tank for topping up pots. I haven't attached it yet, and we've never had one so we don't even know how much it will come in handy.
    I may put hot water into one spout designated for cleaning only, perhaps a handspray on a hose. The metal spout could be cold only after all.
    Actually, since the water heater "precipitates out" many items in the water, it could be "purer" than the cold water.
    What precipitates out is calcium and magnesium hardness, it and anything else becomes concentrated.
    Also, due to the temp settings used today, domestic water heaters are great breeding grounds for bacterial growth. Although most of it is harmless.
    Dec 2009
    northfork, california
    I agree with that, and the water is either sterile or pasteurized too. Much more efficient heating than a stove top too.
    But the issue and advice about drinking hot water comes from ALUMINUM anodes. especially with a corkscrew dip tube that sends the aluminum precipitate into the outlet. Aluminum is well known as a poison with arthritis and possibly alzheimers influence.
    Use a MAGNESIUM anode and a straight dip tube, flush out the tank with a ballvalve at the base regularly.
    http://www.waterheaterrescue.com/pag...er-anodes.html
    http://solarcooking.wikia.com/wiki/Water_pasteurization
    Looks like 140' kills most everything.
  1. Delta 600 up/down single handle shower valve?
    By Kognyto in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-10-2011, 02:33 PM
  2. Putting tub spout on 4 port diverter valve with shower heads?
    By dujour in forum Shower & bathtub Forum & Blog
    Last Post: 01-02-2011, 03:10 PM
  3. Water heater only putting out warm water
    By MikeW888 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-13-2008, 07:43 AM
  4. Single-Lever Valve Does Not Shut Off
    By tromansky in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-19-2008, 12:04 PM
  5. Moen single handle tub/shower valve
    By marichpt in forum Shower & bathtub Forum & Blog
    Last Post: 10-31-2005, 05:19 AM
