Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 51
Thread: DiY or No? Please help me decide. 350' 2hp replacement
  1. #31
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    Using these dims
    http://www.harvel.com/pipepvc-sch40-80-dim.asp
    and 87 # per cu. ft. for the PVC density I think the pipe by itself weighs 142 #.
    What a hassle.
  2. #32
    DIY Junior Member natopotato's Avatar
    Nov 2010
    USA
    YAY!!!! Today my Dad and I built a 14' "pyramid" out of 2x8's etc. Anyway took about 6 hours to build the rig and get the pump out. I will post pictures soon. taking it out in one piece was great advise thank you. with 3 pulleys and the load reduction we where able to easily manage the load. Brought it up 10' at a time and ran it up over a tree and back to the ground.
    My 2hp well was destroyed by a massive ball of electrical tape jammed up in the intake area!! I got a 1.5hp pump from tractor supply. I will be dropping it in tomorrow.
  3. #33
    In the Trades Texas Wellman's Avatar
    Feb 2010
    SE Texas-Coastal
    Congratulations! I learn something new every day. Never tried to pull the sch 80 out in one piece but have done it many times with sch 40 pvc, especially if you have a tree handy.
    Be sure you use the best quality 3M tape when making those splices. And it's always a good idea to look over your wire or replace it if there's any doubt.
    Wonder where all the tape came from? Did you see any evidence that it came off the drop-pipe?
  4. #34
    Moderator valveman's Avatar
    Mar 2006
    Probably didn't have to go over the tree. It will bend more than you think it will. Glad you got it out. Just remember when going back to have everything pre-taped and ready. Then don't let it sit down on the last coupling too hard or it will pop it off.
  5. #35
    Dec 2009
    northfork, california
    You need to buy Scotch #33 tape for the well, and their rubber splicing tape would be a good first coat too. That was a bit of china in your pump intake.
    The installer saved 6 bucks on the install and cost you thousands.
  6. #36
    Well Drilling/Service justwater's Avatar
    May 2010
    NE FL, SE GA
    Good job, wouldn't u have loved have pulled it with only ur hands rather than the tripod? Lol.
    Valveman, it's not that the sch 80 will break. U have to have a descent arc or it will buckle in the connections, especially threaded MxF pipe.
  7. #37
    Dec 2009
    Still say the could have pulled it by hand with some spring loaded grabber cogs, or a clamp block, so they could take a break.
    I drill a bit undersize hole in a block of 4x6, split it on a bandsaw and hinge one end. A threaded rod and a big wing nut, or just a good C clamp makes it a quick pipe locker at any point, not just at the couplers. Works well for lowering 4" liner especially.
  8. #38
    May 2010
    NE FL, SE GA
    Pretty enginuitive ballvalve, a homemade quick clamp. I've also been surprised just how much a good pair of larger vice grips can hold up.
  9. #39
    Who cares how many hundred lbs it weighs when using a tripod and probably a boat winch, block'n tackle, a come along or chain hoist hung on the tripod with a pipe hoop to hold the pipe from falling over while unscrewing the sections thing like in the video Cacher_Chick posted.
    The last item on the page at the first link below. Drop pipe Vicegrip (DPVG at the 2nd link). I used one for PE pipe and I'll bet I could get one to work on PVC. No shock load of 1000#. You migt be able to rent one at a tool rental place; or talk to them and then buy one and resell it to them. Maybe rent one from a pump guy.
    http://www.deanbennett.com/well-accessories-page47.pdf
    http://www.deanbennett.com/pipe-tools.htm
    http://www.campbellmfg.com/catalog/r05.htm
  10. #40
    Aug 2008
    MD
    Quote Originally Posted by natopotato View Post
    So 12 manhours for 350'. Could one person have done it in one long day?
    1.5 hp should give you about 6 GPM. Get a pump that protects itself against reasonably foreseeable hazards.
  11. #41
    Mar 2006
    Quote Originally Posted by justwater View Post
    I have done
    250' setting
    static at 200'
    1.5 HP pump
    with 1 1/4" sch 80
    galv couplings
    with only one guy helping me.
    No winch or clamps, all out in one piece, and I am not that big.
    I have even tested to see how much you can bend it before it breaks at the threads. As long as it is above 50 degrees, you can bend it much more than you think before it breaks.
    A 200' set on 1" poly with a static of 4' and I nearly needed to push the pump down the hole. It was so hard to drag the pipe across the ground that it felt like I was pushing it down the hole.
    Although I would say that it should be easier for someone who has done a few hundred pumps before. It can be risky for someone who has never seen it done. Because just one thing not set up right, and the whole thing could go south on you.
  12. #42
    Jan 2008
    Congratulations! I'm really looking forward to pictures of your tripod setup.
  13. #43
    Nov 2010
    USA
    I have been trying to figure out where the tape came from my best guess is that it was wrapped heavily around the metal clamps holding the torque arrestor in place.
  14. #44
    Nov 2010
    USA
    Here are some pics. I had the timbers from leftover projects and through it together with some deck screws in about an hour.
    Tomorrow the project will be finished I am just waiting on a glued fitting to cure. before dropping the last 40' in to the well.
  15. #45
    Good job. No torque arrestor this time.
  1. How do plumbers decide on what to charge?
    By Maxine in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-08-2013, 06:32 AM
  2. Help needed asap-need to decide now :-( KOHLER K-3611 Highline
    By mpetva in forum Toilet Forum discussions
    Last Post: 07-07-2009, 11:46 PM
  3. Trying To Decide Between The Soiree & Nexus-Any 2 Piece Advantage?
    By sheellah in forum Toilet Forum discussions
    Last Post: 09-07-2008, 08:50 AM
  4. Need help to decide on a toilet
    By George R in forum Toilet Forum discussions
    Last Post: 02-20-2007, 07:58 PM
  5. Toilet + sink plumbing plan: please review -- trying to decide between two plans
    By looknohands in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-27-2005, 10:37 AM
