Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
Thread: Winter problem with gas water heater: gas line too small?
  1. #16
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    Check your gas meter with a clock to see how many cu. ft. per minute your heater is using, then convert to BTUs/hr [of power]. On my gas bill 6400 cu. ft. = 65 therms.
    1 BTU [of energy] raises 1 pound of water 1 degree F and 50 gals weighs about 420 pounds.
    15 minutes @ 2.5 GPM = 38 gals and if the shower water is 110 F only some of this is your 132 F water.
  2. #17
    Entering water in the wintertime is usually much cooler than in the summer, so that creates two problems.
    1. As the water flows through the dip tube to the bottom of the tank it will have a greater cooling effect on the hot water at the top of the tank. And,,
    2. Since the water is colder to start with it takes longer for it to be heated.
    3. Both of these factors will cause the heater to NOT produce the quantity of hot water it does in the summertime.
  1. Empty out lake water line in winter
    By Harpman in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-20-2008, 05:29 PM
  2. Lower Power element for small GE water heater?
    By sedin26 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-02-2008, 09:12 PM
  3. Gas line pipe too small?
    By dhoerl in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-17-2008, 07:31 AM
  4. toilet problem / water supply line problem
    By lampe3d in forum Toilet Forum discussions
    Last Post: 01-16-2007, 02:59 PM
  5. Ice maker line from cold line of water heater?
    By ccash in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-12-2004, 06:20 AM
