The farther North you live, the colder the incoming water is. The temperature differential makes makes the heater work harder. Also, if the heater is in the garage, you will be losing some temperature overnight. Granted, the thermostat is supposed to keep heated water in storage, but unless the water dips to the reset point, you will be losing some heat.
It’s just such a massive drop-off in hot water production from summer to winter, in terms of how long we can take showers in the morning before the hot water runs out… gallons shmallons, I’ll count the gallons just for giggles and for the amusement of this board, but regardless, there shouldn’t be such a dropoff, something’s not right.
