Results 1 to 9 of 9
Thread: Underground metal well cover/house
    DIY Member Greg Mueller's Avatar
    May 2007
    Sometimes WA, Sometimes NM
    Default Underground metal well cover/house
    I'm trying to find out information about these. They are for extreme temperature areas.
    They are like a piece of culvert standing on end with a domed top with a hatch in it. They have no bottom. They are about 6' in diameter and probably the same height.
    The idea is to put your pressure tank/etc in this underground structure in cold weather areas. Since the earth stays at about 50 the stuff won't freeze. I've seen them around Datil (NM), but I'm not there to look now
    My mom is having troubles with critters digging into her well house and knocking the heater over, not to mention the cost of 'lectricity for the heater. When it gets down below the teens she loses her water
    Anybody know a make/model/manufacturer ?
    Dec 2009
    northfork, california
    pipe heat tape would be much cheaper and heat only the pipes enough to keep them from freezing, and since the pump house is now NOT warm, critters wont be so interested. insulate over the tape.
    May 2007
    We've tried a few things.
    Mostly it is the pressure tank that ices up, but the lines, of course, freeze too.
    It's not uncommon to see them down there
    The first time I saw one I thought a UFO had landed
    Dec 2009
    letting a faucet trickle enough to run the pump every 1/2 hour is cheaper than a electric heater, my guess.
    May 2007
    It also is like a metal grain bin with a domed top
    Moderator valveman's Avatar
    Mar 2006
    There are always tradeoffs. The problems I have with those kind of vaults is condensation dripping on everything making copper turn green, drainage, and cost. I tore down an old well house that was always full of critters. I put in a pitless adapter and moved my little tank and pressure switch inside the house. Everything at the well is buried and I put one of those fake rocks over the top of the casing. Life is good.
    May 2007
    I called the local water well place (Williams Windmills in Lemitar) and it turns out they made those underground vaultish things.
    Not too much humidity in Datil. 16-18 inches of rain per year (all on the same day) and 15-20% humidity typically (unless it rains)
    Dec 2009
    I would only use a vault if you also need a tornado shelter.
    Jan 2008
    Virginia Beach, VA
    We used the corrigated drainage type vaults in NM and they worked fine except that the well must still be outside the vault, they are very close to enter and service and you usually had to remove the lid and enter the vault to service anything.
    I like the Pside-Kick since it entered the picture a few years ago. Now the small tank and controls can be installed in or under the house, in a closet or in the garage. Now there's no need to heat or bury anything, it's easy to service, extends the life of the pumping systen, eliminates most water hammer, gives a constant pressure and it's easy to service. Oh Yeh, The Pside-Kick requires very little space, costs a lot less and animals and bugs aren't likely to bother it.
    Porky Cutter, MGWC
    (Master Ground Water Consultant)
  1. Metal to Metal connections
    By valvemistress in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-14-2008, 08:07 AM
  2. underground pex?
    By tedn332 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-10-2007, 08:10 PM
  3. 20.5" metal lid/cover for existing sewage basin
    By yidi in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-04-2007, 10:49 AM
  4. Toilet flange that is PVC & Metal (metal is Rusted)
    By Donnaml in forum Toilet Forum discussions
    Last Post: 01-22-2006, 07:45 AM
  5. PEX Underground
    By Cass in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-27-2005, 10:17 AM
