Thread: Mansfield toilet overflows
    DIY Junior Member noel marais's Avatar
    Nov 2010
    Washington DC
    Question Mansfield toilet overflows
    I have two new Mansfield toilets; one works fine, the other periodically overflows because the trip lever gets stuck and doesn't drop down. It seems like a simple problem but how do I fix it?
    Sometimes a new lever helps, if the one you have is sticking.
    Overflowing the bowl? That would mean the bowl is plugged.
    Using a plunger or closet auger can help with that, though the builder grade Mansfield Alto model is not one I recommend. We remove and dispose of those all the time.
    A toilet has an opening to the drain, so anything added to it should just go down the drain if it is liquid. A solid might temporarily block it until you had the full force of the tank releasing during a flush, but just a water leak into the bowl would just flow out. So, either the toilet trap or the drain line has to be plugged if it is overflowing.
  1. Mansfield toilet overflows
    By noel marais in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-24-2010, 10:32 PM
  2. Toilet tank overflows
    By aaiken in forum Toilet Forum discussions
    Last Post: 08-07-2009, 04:38 PM
  3. What Causes Toilet Bowl Overflows
    By student in forum Toilet Forum discussions
    Last Post: 11-09-2006, 04:44 AM
  4. 2nd toilet overflows when it shouldn't
    By mreece in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-29-2006, 06:51 AM
  5. Basement toilet overflows
    By wjp007 in forum Toilet Forum discussions
    Last Post: 06-28-2005, 07:41 PM
