Originally Posted by
JOMTMON
Barney: thanks for the link however none of the ones shown are similar enough to mine to provide the needed info. I'll save the link for future reference, thanks.
Akpsdvan: Thanks for going thru all that trouble. I assembled it as you described however the little ball sits down on a rubber washer and when the softener goes into the part of the cycle to suction the brine solution, it prevents it from happening. Am I missing a part between the ball and the gasket to prevent this and what is the purpose of the ball in this position. I know the valve must allow the brine solution to be drawn out and then refill the tank to a certain level (controlled by the float) for the next regeneration. I understand how the water flow is stopped, just not the role the ball and "table" play in this whole operation.
