Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
Thread: Best Subfloor option?
  1. #16
    Jan 2009
    Skip the poly- it isn't buying you anything substantial, particulary if the foundation is well drained. If you insist on higher vapor retardency and ultra-low capillary draw from the slab you can seal it twice over with a silane or acrylic based masonry sealer. (In one application the sealer fix the capillary draw issues, but it takes 2x to make much of a dent in the vapor permeance.)
    But the XPS by itself is already a very significant vapor retarder, only one order of magnitude more permeable than 6mil poly, and an excellent capillary break. It's dramatically less permeable than a double-coat of latex paint. At some point enough is enough, and 25mm of XPS is more than enough for almost any basement slab.
  2. #17
    DIY Senior Member pmayer's Avatar
    Jul 2006
    Minnesota
    I am undertaking the same project (you may have seen the same topics in a different thread). I ran into the stair height issue as well, and the code is so tight that it is almost unavoidable if you are putting down anything on the floor. Here is what my inspector allowed me to do. I am extending the bottom step out about three feet (all the way to the wall) and creating a large landing area. The landing area will step down to the floor in a drop that will be only about 5 inches (compared to 8" stair rise), but because the landing area breaks up the stair pattern, giving a visual queue that something is changing, he said it was acceptable. I am, in fact, going to start building this tonight.
    I put down 1" XPS, no poly, and put OSB over it. I would estimate that the total job took me about 45 - 60 minutes per sheet of OSB, which included putting down insulation, taping, cutting the plywood, drilling lots of holes in concrete, etc. Not fun work, but nothing tricky about it either.
  1. Which vent option is better?
    By Louiep in forum Plumbing Forum Discussion & Blog
    Last Post: 01-24-2010, 12:43 PM
  2. Best Option for Bathroom Trap?
    By elgato in forum Plumbing Forum Discussion & Blog
    Last Post: 04-25-2009, 02:22 PM
  3. what is the best grounding option
    By tech526 in forum Electrical Forum discussion & Blog
    Last Post: 03-01-2009, 04:05 AM
  4. Best option for spa wiring
    By restorick in forum Electrical Forum discussion & Blog
    Last Post: 12-06-2007, 11:36 AM
  5. Best option for a 14" rough in?
    By Serendipity in forum Toilet Forum discussions
    Last Post: 02-17-2007, 04:24 AM
