Better solution for tank bolt leaks for Toto toilet?
qtrmiler347
Cooper City, FL
Could not find it in a search here.
Was at the plumbing supplier buying a new tank-to-bowl seal for my Toto Drake, and a guy recommended I sandwich the small tank holes with a rubber gasket on each side of the hole (along with nut and stainless washer to crush the rubber seals), and then use that same bolt and another set of nuts and stainless washers to bolt the tank onto the toilet. This sounds like a great idea and would reduce the chance of tank leaks or cracking in the small hole on each side of the tank since now it only needs to be tight enough to make the main tank-to-bowl gasket seal up.
Thoughts? Sounds good?
That would work, though we and all of our customers get by just fine with the bolt kit that comes with the toilets.
The bolt kit from TOTO includes two brass bolts, two rubber washers, four stainless washers and four brass nuts.
We put the rubber washer on the bolt, and then drop the bolt through the tank. Take a washer and nut, and tighten.
Then we place the tank on the bowl, and use a second washer and nut to secure the tank to the bowl.
Have you checked to see if the large 3" nut is tight, that is the most likely location of a leak.
Installing a Toto Drake
qtrmiler347
Cooper City, FL
Will look at that as well. Thanks for the suggestions.
qtrmiler347
Cooper City, FL
Follow up:
Sandwiched the tank with rubber washers (as in picture above but used rubber washers on both sides of the tank just to be extra sure). Put vaseline on the tank-to-bowl gasket so that it would slide as opposed to tear (the guys who installed the toilet originally managed to tear the bowl to tank gasket). Anyhow problem solved. I also sanded the inside of the tank in the boltholes area as well to be sure it's flat.
Petroleum products and many rubbers do not mix...a better thing than Vaseline is just some liquid dishsoap. On some rubbers, it just ends up slowly disolving the rubber.
Gary Swart
Yakima, WA
You don't need a better or different solution. All you have to do is follow the instructions and you won't have a leak.
qtrmiler347
Cooper City, FL
I guess I will find out if it dissolves the rubber gasket. What's done is done. I have another one just in case.
