Results 1 to 8 of 8
Thread: good quality shower valves for low pressure system
    DIY Junior Member bigwooo's Avatar
    Sep 2009
    BCS Mexico
    Default good quality shower valves for low pressure system
    I'm in the process of building an off grid home in Mexico. My system relies on a 12 volt pump, pumping out of an underground storage tank to a pressure tank. My pressure switch will be set a 30-50 psi, meaning when the pressure drops to 30 psi, the pump will turn on and fill the pressure tank until it reaches 50psi. I cannot provide more than 50 psi with a 12v pump.
    My plumbing will be 1/2" PEX on a "home run" system.
    I'm looking for suggestions for high quality shower valves that don't cause an appreciable decrease in pressure. I've had experience with some "water saver" valves that don't work well at all in the pressures I've described. If possible, I would like to buy old fashoned basic hot and cold adjustable valves without pressure balancing, temp adjusting etc., if they are still available somewhere.
    Any suggestions would be greatly appreciated.
    Thanks.
    In the Trades Jerome2877's Avatar
    Aug 2009
    BC
    The water saver is in the shower head not the valve, most new valves are pressure balancing but I have seen some old style still available in some stores and they state on them not for use in new contruction.
    Mexico code could be different.
    Sep 2009
    BCS Mexico
    Ahhh... thank you, you're correct. I remember now, it was the shower head...not the valve that caused the pressure issues I had a while back; but...I don't have experience with the pressure balancing valves on lower pressure. I don't have a problem installing one if I can determine it will work OK.
    Most people around here buy the cheap old style valves available locally, but they don't last. I'd like to purchase something that's not going to have to be replaced in 6 months. Does anyone know if pressure balancing valves cause a significant drop in pressure? Any brand preferences. BTW, I had to laugh...Mexico has no codes
    If you have 30 PSI, then any of the Delta, Moen, Grohe and Kohler will work for you.
    You can get parts for these, and the quality is good.
    That's at the low end, but it works.
    Dec 2007
    Many many people on well systems have 30-50 psi pressure switches and have no complaints.
    In Mexico I'd be more concerned that the plumber Installed a trap on the tub/shower than the valve.
    A pressure balancing valve will only cause a DROP in pressure, if the hot or cold pressure drops and then the PB will balance the other one to the same pressure, which will be seen as a pressure drop. Without the PB valve, that same effect will cause a surge of hot to cold water in the shower.
    Sep 2009
    BCS Mexico
    Thank you for all the information. Right now I have a 20/40 pressure switch, but just ordered a 30/50 that I'll be picking up on a trip North. (20/40 is all that's available in Mexico). It looks like I have a good choice of valves for that pressure.
    Muchas Gracias.
    Sep 2009
    BCS Mexico
    Quote Originally Posted by Redwood View Post
    You are soooooo correct. My guest house doesn't have any. Unfortunately I wasn't here to supervise. Now that I live here "things will be different".
  1. Looking for good quality fiberglass/acrylic shower base and sliding doors
    By bases in forum Shower & bathtub Forum & Blog
    Last Post: 11-02-2010, 12:48 AM
  2. Need good quality shower stall
    By dtschak in forum Shower & bathtub Forum & Blog
    Last Post: 04-24-2010, 11:39 AM
  3. Need a good quality sink.
    By ingeborgdot in forum Plumbing Forum Discussion & Blog
    Last Post: 03-17-2010, 06:36 AM
  4. Good place online to find old shower valves
    By hugscot in forum Shower & bathtub Forum & Blog
    Last Post: 05-09-2008, 01:18 AM
  5. Good quality shower valve
    By Leemonster in forum Shower & bathtub Forum & Blog
    Last Post: 04-25-2006, 09:38 AM
