Results 1 to 6 of 6
Thread: Mansfield toilet overflows
    DIY Junior Member noel marais's Avatar
    Nov 2010
    Washington DC
    Question Mansfield toilet overflows
    I have two new Mansfield toilets; one works fine, the other periodically overflows because the trip lever gets stuck and doesn't drop down. It seems like a simple problem but how do I fix it?
    Jan 2006
    Rosedale, Md
    What do you mean by overflows? that term normally means water running on to the floor
    Nov 2010
    Washington DC
    That's right--gallons of water on the floor. It happened twice (on different days)--nothing solid in the toilet. It hasn't happened again (I don't use it very much) but I'm worried that it will happen when a guest uses it.
    What *does* happen more frequently is that the valve doesn't close, and water keeps flowing into and out of the tank. I have to manually dislodge the lever so it will drop down and allow the valve to shut.
    Did you post in the toilets forum? Same answer. You have a clog in the pipe somewhere or in the toilet. Regardless of how much your toilet leaks, any added water should overflow the bowl's weir and run down the drain. If that path is plugged, then it will back up and overflow the top of the bowl. Think about it...you have a 3/8" water pipe coming in and a 3-4" drain pipe under the toilet...no way you can run water into the toilet faster than that pipe can drain unless it is plugged somewhere along the way.
    A toilet will NOT overflow, regardless of how long the water is running from the tank, UNLESS, the drain line is obstructed so the water fills it up and then the toilet will overflow. You must have some kind of sewer problem, or a slow septic tank if you have one.
    Yakima WA
    I believe you have 2 problems. First, the flapper is not doing its job of sealing the tank after flushing. This means the water will never fill the tank and will continue to run into the bowl. This by itself would only waste water as the water would continue to the drain. The second problem is a clogged line. If the flapper was functioning properly, the water would overflow after a flush but would stop as soon as the flushing was complete. A problem indeed, but it would not continue as the flapper would close and stop additional water from entering the bowl.
  1. Replies: 11
    Last Post: 08-03-2010, 07:03 PM
  2. Toilet tank overflows
    By aaiken in forum Toilet Forum discussions
    Last Post: 08-07-2009, 04:38 PM
  3. What Causes Toilet Bowl Overflows
    By student in forum Toilet Forum discussions
    Last Post: 11-09-2006, 04:44 AM
  4. 2nd toilet overflows when it shouldn't
    By mreece in forum Plumbing Forum Discussion & Blog
    Last Post: 09-29-2006, 06:51 AM
  5. Basement toilet overflows
    By wjp007 in forum Toilet Forum discussions
    Last Post: 06-28-2005, 07:41 PM
