Results 1 to 7 of 7
Thread: Faucet Connection Size
    DIY Junior Member sobershea's Avatar
    Sep 2010
    Michigan
    Question Faucet Connection Size
    A review on the kitchen faucet I am interested in stated that "The water lines on this faucet are smaller than my existing faucet, so my water pressure has diminished considerably." The specifications on the faucet list a "Connection size" of 3/8" Compression. If I hadn't read the review I would have purchased the faucet, however, my water presser isn't that hot and I am concerned that the "connection size" could be an issue. Other faucets have a 1/2" connection size. So, can I blindly purchase a faucet based on looks, or do I need to take connection size into consideration?
    TIA
    One who lurks Basement_Lurker's Avatar
    Jun 2007
    Victoria, BC
    It makes no difference. The outlet on your shutoff valve is 3/8, and the supply tubing you would be using is 3/8. A number of kitchen faucets are now coming with the option of having the 3/8 flex lines already installed directly into the faucet body.
    Broken promises don't upset me. I just think, why did they believe me? -Jack Handy
    www.blackbirdkitchenandbath.com
    The Feds have put limitations on the flow rate of many valves used in a home. You can easily reach that max flow with a 3/8" line. There may be some older ones still on a shelf somewhere, but even then, a 3/8" supply line is/was fairly typical.
    The restriction is at the aerator, not the supply lines.
    We've been using 3/8" for over fifty years.
    Shower heads, kitchen faucets and bathroom faucets all have restricters in place, but not at the supply line.
    Plumber jimbo's Avatar
    Even when the faucet had 1/2" IPS inlet connections, the internal tubing was much smaller. And for years, ALL the flex lines we have used were the same ( approx 3/8) tubing, just with 1/2 or 7/16 or 3/8 ends on it.
    Sep 2010
    Michigan
    Thanks for all the input. Faucet is ordered. Thanks again!
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    Using this
    http://www.irrigationtutorials.com/copperloss.htm
    and fitting an equation to the values given for type K copper at 2 GPM, for a 3/8" tube the pressure loss will be twice as much as for 1/2", 8 PSI rather than 4 PSI, but this is per hundred feet of pipe.
    Fuhgedit.
  1. Stupid Newbie Question - Leaks in new faucet connection
    By Timber47 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-13-2010, 07:25 AM
  2. Outside faucet has wrong thread size (pipe threads vs hose threads?)
    By NiceMustang in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-21-2010, 05:36 PM
  3. size hole for single hole faucet
    By bobbieK in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-14-2009, 01:31 PM
  4. Size a faucet to the room size?
    By chrisexv6 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-06-2008, 07:09 AM
  5. Connection Leaking on Frost Free Faucet
    By groovychic in forum Irrigation / Sprinkler Forum
    Last Post: 08-14-2007, 06:13 AM
