Results 1 to 9 of 9
Thread: hot cold reversed? single back and forth handle in kitchen
    DIY Junior Member 68malibu383's Avatar
    Dec 2009
    Colorado
    Default hot cold reversed? single back and forth handle in kitchen
    Hi,
    This is a faucet with a single arm on the side of the fixture that you tilt downward at about a 45 degree angle to get water to flow. Then push it back (counterclockwise) and forward for hot and cold. I think hot should be on when pushing handle back (counterclockwise). Is this correct, or should hot be forward? Thank you!
    Jan 2006
    Rosedale, Md
    If we knew the brand and model we could answer the question easier
    Hot is back or to the left.
    If you would like to fix the problem go underneath your sink, turn the 2 valves to the off position, turn on the faucet and make sure the water is off, take the 2 supply lines and switch them from whatever they are connected to to the opposite one as long as they will reach. If the supply lines are not flexible, I would suggest that you go to a big box store and buy 2 flexible supply lines and replace what is there with the new lines. This is something that is taught in first year plumbing school. Have a nice day.
    Dec 2009
    Colorado
    Thanks. I'll get it right.
    Please drop 150.00 in the mail for me. lol Thank you.
    Once you become a regular customer you will get a 25% discount off of my regular prices.
    45 degrees downward, back, counterclockwise, and forward may mean something to you, but I cannot figure out where the handle is located on the faucet, or which way the handle is moving. Often with single handle faucets it is just a matter of rotating something 180 degrees to change the orientation of hot or cold.
    I understand that about Moens but what other ones can that be done with?
    One who lurks Basement_Lurker's Avatar
    Jun 2007
    Victoria, BC
    Moen and Delta single cartridge units can reverse their intakes. I only install the occasional american standard faucet or p.i.a. grohe, but I think they can as well.
    Broken promises don't upset me. I just think, why did they believe me? -Jack Handy
    www.blackbirdkitchenandbath.com
    Delta kitchen faucets do not reverse, but some versions of Grohe, and those that use a "tubular core" do.
  1. Help - Delta Single Handle kitchen faucet
    By rsmith99 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-17-2010, 06:40 AM
  2. Moen Single Handle shower- no cold water???
    By b00mstick11 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-24-2010, 02:29 PM
  3. single handle kitchen faucet
    By drake in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-26-2010, 06:20 AM
  4. Moen single handle kitchen faucet
    By jim642 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-28-2008, 06:54 PM
  5. MOEN Single Handle Kitchen Faucet Repair
    By novicefromma in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-10-2007, 04:35 PM
