Thread: Wiring a pulsafeeder chemical solution pump
    DIY Junior Member Wellmate's Avatar
    Nov 2010
    Bonney Lake WA
    Default Wiring a pulsafeeder chemical solution pump
    I want to wire a pulsafeeder pump(220v) so it runs when the well pump is charging the pressure tank. Do i wire it to the pressure switch itself....or to the well pump control box. Any ideas. Thanks
    Dec 2009
    Alaska
    In the past I have done it to the pressure switch with a so call pig tail, a short run from the switch with a female and then a male on the pump end so that if needed the pump can be unpluged with out turning off the well pump to undo the wires.
    I always used the switch to a metal receptacle box.
    Previous member
    Jul 2009
    North of the Mason dixon Line
    Wire it right into the pressure switch
  1. Pulsafeeder Chemical Feed Pump wiring
    By Wellmate in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-12-2010, 06:08 AM
  2. electric circuit for chemical reaction
    By aeacfm in forum Electrical Forum discussion & Blog
    Last Post: 11-07-2010, 12:09 PM
  3. Best solution for outdoor wiring
    By TequilaMB in forum Lawn Care/Landscaping
    Last Post: 06-19-2010, 08:05 AM
  4. Chemical odor from central heating's chimney
    By Bill Calley in forum HVAC Heating & Cooling
    Last Post: 12-26-2008, 06:05 PM
  5. Well Pump Wiring
    By Giles in forum Electrical Forum discussion & Blog
    Last Post: 11-22-2008, 06:50 PM
