Thread: Pulsafeeder Chemical Feed Pump wiring
    DIY Junior Member Wellmate's Avatar
    Nov 2010
    Bonney Lake WA
    Default Pulsafeeder Chemical Feed Pump wiring
    I am installing a pulsafeeder chemical solution pump (220v) in my well water supply line just infront of the pressure tank. I would like to install it so it operates when the well pump is running and filling the pressure tank. My question is......do i wire the pulsafeeder pump to the pump switch itself...or to the control box or???. I would like to know, where i need to cut the wires and splice it in...or if i just wire it to existing terminals. Thanks in advance
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    Quote Originally Posted by Wellmate View Post
    Wire it in parallel with the well pump motor, assuming the chem. pump motor is also 220v. Depending on the current draw of the chem. pump you might need to resize wire or breakers or make other adjustments.
    Moderator valveman's Avatar
    Mar 2006
    You can wire it to the "load" side of the pressure switch, or tie it in with L1 and L2 in the control box.
  1. electric circuit for chemical reaction
    By aeacfm in forum Electrical Forum discussion & Blog
    Last Post: 11-07-2010, 12:09 PM
  2. Chemical odor from central heating's chimney
    By Bill Calley in forum HVAC Heating & Cooling
    Last Post: 12-26-2008, 06:05 PM
  3. Well Pump Wiring
    By Giles in forum Electrical Forum discussion & Blog
    Last Post: 11-22-2008, 06:50 PM
  4. Wiring Sub. pump
    By natepyoung in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-28-2008, 10:09 AM
  5. Wiring AMT Pump
    By farmer in forum Irrigation / Sprinkler Forum
    Last Post: 05-02-2007, 06:33 PM
