IT goes together just like the drawing shows and ALL gaskets go behind or under the tub. NONE go inside the tub. The installation should be so intuitive that I don't know anywhere to find a step by step procedure. Which is also why the only send a parts breakdown. Put the drain in the bottom of the tub, the overflow at the upper opening, and then do whatever is necessary to connect them to the drain tee.
