Results 1 to 5 of 5
Thread: Digital water softener manual regeneration mode?
    DIY Junior Member myaroch's Avatar
    Nov 2010
    Pa
    Default Digital water softener manual regeneration mode?
    I'm interested in a water softener but for the first couple of months when I install, I will need to hook a garden hose up and run a manual regeneration when needed. In the spring I will be able to hook up a drain and run on automatic. Do any of the digital control softeners offer a manual regeneration only mode that will not use their auto feature if set this way?
    Previous member
    Jul 2009
    North of the Mason dixon Line
    I assume the hose is on the drain line? and for some reason you can not run a proper drain at this time?
    Dec 2009
    Alaska
    You could always leave it unplugged between regen cycles.. plug it in, start the cycle with the drain going to where you wish and then unplug it when it is done..
    Setting the water hardness to the lowest number, even zero if possible, would delay the automatic regeneration. So if you knew when it would happen, assuming yours tells you how many gallons of water were used, then you could do the manual one ahead of time.
    The best is to put the discharge into the septic or sewer system.
  1. New homeowner...existing water softerner...no manual...not regenerating
    By msomerville in forum Water Softener Forum, problems, installation and reviews
    Last Post: 06-12-2010, 03:46 PM
  2. Culligan water softener stuck on regeneration
    By shiv in forum Water Softener Forum, problems, installation and reviews
    Last Post: 04-22-2010, 07:41 AM
  3. Replies: 0
    Last Post: 01-25-2010, 10:39 PM
  4. water softener mechanical vs digital meter?
    By tylertj in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-20-2007, 06:21 PM
  5. Water Softener Regeneration
    By jbschaefer1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-08-2006, 04:52 PM
