Results 1 to 2 of 2
Thread: two zone circulator electrical connections taco to becket afg
    DIY Junior Member d trois's Avatar
    Nov 2010
    Boston, MA
    Default two zone circulator electrical connections taco to becket afg
    would attaching the two taco's to c1 and c2 on the aquastat and the two thermostat wires to the tt work. Or do i need to use a taco relay board with 2 or 3 zones? Anyone know?
    Previous member
    Jul 2009
    North of the Mason dixon Line
    sure it will work. when you turn either thermostat up, both circulators will run. I assume though that that is not your intent so, yes you will need another relay to call the 2nd zone. You can go with a Taco relay or a honeywell 89a or 854 or one of the newer electronci versions. Either way you need to isolate the thermostats and circulators from each other. Wiring diagrams can be found at www.taco-hvac.com
  1. Taco 006 BC4 Circulator pump running 24/7?
    By scottall in forum Water Heater Forum, Tanks
    Last Post: 03-18-2010, 07:42 AM
  2. Taco circulator info/advice sought
    By Mainuh in forum HVAC Heating & Cooling
    Last Post: 11-26-2007, 08:52 AM
  3. taco circulator wiring
    By litemine in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-25-2007, 03:28 PM
  4. Taco Flo check circulator pump
    By MarkHash in forum HVAC Heating & Cooling
    Last Post: 10-04-2007, 08:23 PM
  5. Taco 003 Hot Water Circulator Pump Runs Hot!
    By gplumb in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-24-2007, 05:30 PM
