Thread: Natural Gas Line Clogged
    DIY Junior Member WEldred's Avatar
    Nov 2010
    New Jersey
    Default Natural Gas Line Clogged
    Hi experts,
    Background:
    I had a 20-year old gas fireplace that worked fine until several years ago when I started losing pressure (though I didn't know that at the time and thought it was a regulator). Last year, I went ahead and purchased a new burner/log set. In the process of upgrading the fireplace, the installer and I discovered that the end of the gas line was completely blocked with a hard black powder. We broke up the powder, vacuumed it out, and, surprise, everything was working fine.
    Fast forward to today:
    It's a year later and I'm seeing similar symptoms with the new set. The pilot is fine until I turn the fireplace on, then the pilot lowers and the thermocouple shuts off the fireplace after a few minutes. I assume if I disconnect the fireplace from the pipe in the base of the hearth that I'll see the same black buildup.
    My big question - what's this build up and why did the fireplace work for 20 years before it started being a problem. (Granted, I bought the house 8 years ago, so maybe it's always been a problem). I'm just trying to figure out the correct way to fix this
    Thanks for any thoughts or pointers !
    Ward
    Dec 2009
    northfork, california
    Add a trap at the end of the line before the shut off valve.
    Consider a new line as this is the pipeline itself likely deteriorating. Old age does interesting things.
    Nov 2010
    New Jersey
    Hi Ballvalve,
    Thanks for the info and recommendation !
    Ward
  1. Natural Gas Line Extension Clogged?
    By yehudi in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-05-2009, 01:35 PM
  2. Natural gas line????
    By figs in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-07-2009, 10:12 AM
  3. Natural Gas Line
    By rickeys in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-01-2009, 07:11 AM
  4. outside natural gas line
    By george58 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-26-2007, 03:32 PM
  5. Natural gas line
    By Weaselpolooza in forum Remodel Forum & Blog
    Last Post: 11-06-2006, 04:12 PM
