Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
Thread: Need advice on wiring sump pump outlet for emergency generator / 220v split to(2)120v
  1. #16
    DIY Member TSPORT's Avatar
    May 2005
    Philly,PA suburbs
    I decided to heed the advise on the GFCI and revamped my project. Went with a 125V inlet receptacle in the garage for a regular extension cord to the generator when in use. The receptacle is hard wired to a GFCI outlet in the basement. Already had the 12/3 WG run so I just capped off the extra conductor. All tested and working properly.
    Thanks guys - TSPORT
  2. #17
    Maybe you should just do what 95% of people would, and install your wiring without asking for permission, assuming YOU know what you are doing.
  3. #18
    Jun 2007
    North Carolina
    As a side note in some cases your home insurance company can come after you for work that is not inspected in the event something goes wrong.
  1. emergency advice fast
    By bbillcee in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-09-2010, 06:48 AM
  2. steam generator - wiring 8kw on 30amp break
    By Poisson Cru in forum Electrical Forum discussion & Blog
    Last Post: 11-18-2009, 05:25 PM
  3. 120V to 12V AC Transformer Wiring Question
    By Doug Parsons in forum Electrical Forum discussion & Blog
    Last Post: 10-30-2008, 05:49 PM
  4. Sump pump advice
    By Alpo in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-03-2008, 08:38 AM
  5. heated 120v floor and thermostat wiring
    By Andrew M in forum Electrical Forum discussion & Blog
    Last Post: 08-07-2007, 07:32 PM
