Results 1 to 5 of 5
Thread: Washing machine / laundry tub plumbing
    DIY Junior Member bradatkins's Avatar
    Nov 2010
    Canada
    Default Washing machine / laundry tub plumbing
    Hi -
    I'm looking at dry walling my basement walls in my laundry room. Before I do that, I wanted to make sure what I have is OK.
    If it's not, any suggestions to clean it up if necessary would be appreciated.
    Brad
    Are you putting a vent on the laundry tub trap arm before it enters the stack? The vent should be vertical until it's above the standpipe for the washer.
    Nov 2010
    Canada
    Hey Terry -
    Currently the vent comes into the p-trap arm (ie at the end of the ptrap) horizontally (ie not from the top).
    Are you saying that the last section of the vent pipe that's running horizontally needs to come in vertically on the p-trap arm?
    I've attached another diagram. My apologies if I'm not understanding correctly.
    Thanks for your patience.
    Brad
    Plumber jimbo's Avatar
    A vent pipe can not be horizontal ( lower than 45) until it is 6" above the rim of the highest fixture...the sink or standpipe. By convention, we use 42" above floor level for that reference.
    Nov 2010
    Canada
    Ahh ok, so like the revised attached?
  1. Washing machine & laundry sink venting
    By hoffmand in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-15-2010, 06:02 PM
  2. Washing machine plumbing problem
    By nickb7 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-21-2010, 06:00 PM
  3. laundry: washing-machine clearance from switches
    By rerickson in forum Electrical Forum discussion & Blog
    Last Post: 04-07-2010, 04:06 PM
  4. Moving Plumbing for Washing Machine?
    By wakefield.chris in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-28-2010, 01:14 PM
  5. Basement Laundry Tub & Washing Machine question
    By Ched in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-27-2010, 12:51 PM
