Thread: Couple Tub Surround Questions
    DIY Member PM5K's Avatar
    Oct 2006
    San Antonio, TX
    Default Couple Tub Surround Questions
    First question: I saw a nice surround and it said something like "installs directly to studs". Does that mean I can't use it if I already have drywall installed, or does that mean it can be used either way but has the advantage of being able to be installed directly to the studs if you desire?
    Second question: I've read a little and what I read indicates that a five piece surround is better to use in situations where your walls are not 100% squared. One of the walls is, but the other is not. How do I decide how many pieces to use? Are 5 piece surrounds more likely to possibly have leaks because there are more seams as opposed to a one or three piece?
    TIA!
    Each seam is a potential leak point...
    The surround walls probably have a flange that is designed to be covered by the drywall that butts up to it. It adds stability and strength. It would look lousy sitting on top of your drywall, so you might just want to tear the drywall off, square up and plumb the walls, install the new surround, then replace the drywall needed to cover things up.
    To square up the walls, you could sister new studs next to what you have, or add shims. You might also be able to plane them, but that takes more skill.
    Five part surrounds probably have corner pieces that secure to the surface of the wall panels. If so, the will ALWAYS be a potential leak source, since it can be difficult to keep them adhered to the walls.
  1. Couple of quick questions....
    By Master Brian in forum Electrical Forum discussion & Blog
    Last Post: 10-28-2009, 10:57 AM
  2. A couple of DWV questions
    By JohnDavid in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-15-2009, 03:33 PM
  3. A couple of DWV questions
    Last Post: 04-03-2009, 06:11 AM
  4. A couple of questions.......
    By mommy2krj in forum Toilet Forum discussions
    Last Post: 03-14-2008, 03:49 AM
  5. Couple Plumbing Questions...
    By jgray152 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-21-2007, 03:25 AM
