I am remodeling my tub area and the tub spout is currently located where the overflow would normally be. This end of the tub is an exterior wall. The faucet is in the wall on the long side of the tub. I would like to move the spout up into the wall, but that will put the pipe in the exterior wall. Is that a problem? I am using this faucet (http://www.hansgrohe-usa.com/us_en/121090_31373335315F32375F3530343133.htm).
I plan to use the tub primarily as a shower and will only very occasionally use the tub spout. Will the diverter keep water out of the pipe between the valve and the tub spout if I am not using it? What about when the shower is off? Will there be water remaining in the pipe between the valve and tub spout that could potentially freeze in the exterior wall?
