Results 1 to 6 of 6
Thread: Venting kitchen sink below window
    DIY Senior Member jastori's Avatar
    May 2008
    Illinois
    Default Venting kitchen sink below window
    We have an unvented kitchen sink (old plumbing, never vented). The sink is below a window, and the nearest access for a vertical vent up is about 3-4 ft away horizontally.
    I don't think we can get 6" above fixture rim due to the window height. Is the island venting approach the best? I have seen references to the "dirty arm" approach but am not sure exactly what the details would be. I also understand AAV, but would like to avoid it if possible.
    We are in Illinois, and I will discuss the details of the approach with our plumbing inspector, but wanted to understand what the options are first.
    Thanks very much!
    Dec 2007
    You can run the drain and vent alongside the window then extend a dirty arm across to the sink.
    May 2008
    Illinois
    Thanks very much for the quick reply.....
    Can the dirty arm go 3-4' horizontally for a 2" pipe? This is a load bearing wall, so, I am also concerned about whether I can drill for the 2" horizontal run through standard 3 1/2" studs. It would have to pass through at least 3 studs.
    A 1.5" dirty arm can be 42" long, and a 2" dirty arm can be 60" long.
    Can you run the pipe beside the wall for a while (inside kitchen cabinets) instead of cutting studs?
    Jun 2009
    Canada
    Pretty sure sinks have been below windows for years... My kitchen sink just has a long trap arm before the tee...
  1. venting question kitchen sink under window
    By gsici in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-02-2010, 08:09 AM
  2. Venting the kitchen sink
    By nh3 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-14-2008, 02:06 PM
  3. Venting a kitchen sink
    By jpiazza in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-12-2007, 06:20 PM
  4. Kitchen Sink Venting
    By massillonmarine in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-08-2007, 07:59 PM
  5. Challenge routing kitchen sink vent around window
    By codys in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-23-2005, 06:10 AM
