Thread: Navien Tankless Water Heater---Well Pump Setting
    DIY Junior Member JTCA's Avatar
    Nov 2010
    Indiana
    Default Navien Tankless Water Heater---Well Pump Setting
    I just installed an NR-180A. The system has a well pump. What does the well pump setting do and how in the world do you set it?
    The Operation Manual (page 23) seems like a very poor translation or maybe has the wrong information.
    Can anyone shed some light on this?
    DIY Senior Member zl700's Avatar
    Aug 2009
    Texas
    Changes in pressure equates to fluctuations in flow. When flow changes, the burner can't react quick enough resulting in water temperature fluctuations and spikes.
    Enabling the well setting evens out the burner operation.
    It is quite easy to turn on following instructions on that page, changing the C to a S (set)
    A NR 180 in Indiana? Hope it's a 1 bath house, 150,000 btu unit for that region is undersized for any more than that.
    If Payback is so important to you, why are you not driving a Toyota Corolla?
    Nov 2010
    Indiana
    Thanks for the information. Yep, one bath and working very well in fact.
  1. Navien Tankless Water Heater Comments and questions
    By willl in forum Tankless Water Heater Forum
    Last Post: 04-28-2013, 10:16 PM
  2. Smell of Gas - Navien Tankless Heater
    By cawhitehead in forum Tankless Water Heater Forum
    Last Post: 08-21-2011, 05:43 PM
  3. Navien Tankless and Hot Water Circulator
    By mn4az in forum Tankless Water Heater Forum
    Last Post: 01-29-2010, 10:39 AM
  4. Temperature setting for each water heater element
    By ron in sc in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-28-2008, 12:43 PM
  5. Temperature setting on new mod-con boiler/water heater
    By Montalvo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-12-2007, 08:22 AM
