Results 1 to 2 of 2
Thread: Lengthining plastic drain pipes, probably a dumb question???????
    DIY Junior Member nelson84's Avatar
    Sep 2009
    Canada
    Default Lengthining plastic drain pipes, probably a dumb question???????
    I need to lengthin a drain pipe for a sink in the wall. I need to add about 8 inches horizontally and then have it come out of the wall to the sink. After cutting the pipe and adding the longer section, do I just smear the glue inside the fitting and on the pipe and stick them together? Is it just one type of glue or do I add some epoxy and another type of glue? What I am getting at is what is the glue that is used to glue the black plastic drain pipes? How much do you use? What is the best tool for cutting the black drain pipe? A sawsall???
    In the Trades Jerome2877's Avatar
    Aug 2009
    BC
    You need abs glue, put it on the inside of the fitting and on the pipe then push and twist slightly (this spreads the glue nicely) and hold for a few seconds, then wipe the excess glue. The best way to cut abs is with a tube cutter with a plastic wheel, but a hacksaw will do just fine, try to cut as straight as possible and trim off any burrs.
  1. Question 752: Tub drain, plastic w/slip nuts or sch 40 glued.
    By hhcibtpaun in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-21-2009, 12:02 PM
  2. I hope this is a dumb question...
    By crosby1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-05-2008, 03:33 AM
  3. Maybe a dumb question, but.........
    By TerryT in forum Shower & bathtub Forum & Blog
    Last Post: 12-30-2006, 06:16 AM
  4. Most likely a Dumb question
    By molo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-10-2006, 04:14 PM
  5. dumb thinset question
    By Richard S in forum Remodel Forum & Blog
    Last Post: 03-01-2005, 08:24 PM
