Results 1 to 5 of 5
Thread: Flapper leaking on AS Lexington 1-piece
    Default Flapper leaking on AS Lexington 1-piece
    The flapper is worn and needs o be replaced. Can I just replace the black rubber or does the whole flapper kit need to be replaced?
    Jan 2006
    Rosedale, Md
    You should be able to replace disc only. You don't have a habit of using the handy cleaners that drop into the tank, do you?, some of them will deteriorate the mechanism
    You can just replace the disc, UNLESS, you break its retaining "pin" off when you remove the old disc.
    In the Trades Jerome2877's Avatar
    Aug 2009
    BC
    Be careful when removing it as HJ said if you break the pin you have to replace the whole thing. The problem is that your model takes a different size than the regular AS part. I had to have one ordered in from AS last year and it took a few weeks.
    yep found just the disc and that solved the problem. thanks guys
  1. leaking toilet after 2 flapper changes
    By nabril in forum Toilet Forum discussions
    Last Post: 03-02-2014, 08:11 PM
  2. New Toto Drake 2-piece leaking between tank and bowl
    By Davebutch in forum Toilet Forum discussions
    Last Post: 01-15-2012, 10:44 AM
  3. 1997 Am. Std. Lexington (2037) one piece 1.6 gal/slush
    By Alan Muller in forum Toilet Forum discussions
    Last Post: 05-17-2010, 11:06 AM
  4. Leaking one-piece wall hung toilet
    By Guest in forum Toilet Forum discussions
    Last Post: 01-25-2008, 05:36 PM
  5. One piece fiberglass bath tub leaking to floor below
    By rmk9785e in forum Shower & bathtub Forum & Blog
    Last Post: 05-25-2006, 10:51 PM
