Results 1 to 2 of 2
Thread: Toilet Flange Extension
    DIY Junior Member ak99588's Avatar
    Jun 2011
    Copper Center, AK
    Default Toilet Flange Extension
    I am working on replacing a leaking toilet and need some advice on getting a good water-tight seal. The flange is sitting 1/4"-1/2" below the vinyl and underlayment, which is what may have caused the leaking. I have a new wax ring-Harvey's No. 10 with extra-thick wax. Are there extensions I can get to install on top of the flange to raise it to floor level before seating the new toilet? I am REALLY hoping to avoid another leaking problem!
    Jeff
    Many choices...the best would be to reset the flange to on top of the finished floor. Then, yes, there are flange extenders. There are also some waxless seals that have a funnel like piece that would take care of that (Fluidmaster and Fernco are two brands). Or, you could use two wax rings, one with a funnel, one without. The one with the funnel on top so the funnel helps keep the bottom one centered and so it can't smush into the drain to create a blockage. Normally, a single one with a funnel can be more problems than it solves, but when things are low, it can help.
  1. Toilet flange extension
    By Fastclient in forum Toilet Forum discussions
    Last Post: 09-20-2009, 04:32 PM
  2. Toilet Flange Extension
    By darmstro in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-03-2009, 03:55 AM
  3. Toilet installation - flange extension
    By DIYMike in forum Toilet Forum discussions
    Last Post: 07-21-2005, 07:56 AM
  4. Toilet Flange pipe to 90 bend: Extension
    By mccutch2 in forum Toilet Forum discussions
    Last Post: 05-18-2005, 11:52 AM
  5. Cast iron flange or flange extension (?) below tile floor
    By gardengirl in forum Toilet Forum discussions
    Last Post: 12-31-2004, 09:54 AM
