Results 1 to 2 of 2
Thread: Brass nipple for side connections?
    DIY Junior Member sbeach's Avatar
    Oct 2010
    WA
    Default Brass nipple for side connections?
    I would like to use the side connections on my WH for radiant heat and am trying to figure out if I can/should use brass nipples in the side connects? Are there any problems with this or should I use something else?
    If those openings are designed for a solar connection, and are not just alternate supply openings, then brass nipples will work.
  1. Tub drain and stack side by side... how to connect
    By louk in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-12-2008, 08:55 AM
  2. How to remove steel nipple from brass tee?
    By Joerg in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-06-2008, 11:04 AM
  3. Kitchen aid Superba side by side fridg...
    By chris fox in forum Remodel Forum & Blog
    Last Post: 07-30-2007, 04:40 PM
  4. Brass Pipe Thread Connections...
    By OldPete in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-19-2006, 05:32 PM
  5. Cutting a brass nipple
    By MikeG in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-25-2005, 06:59 AM
