Page 2 of 2 FirstFirst 12
Results 16 to 18 of 18
Thread: Electric Tankless or new Heat Pump type
  1. #16
    The heatpump versions typically have slow recovery rates, so having more hot water stored may be a big advantage. In order of typical response (faster first), you'd have: gas, electric, heatpump. So, especially if the 80-gallon job was well insulated, it may not be too large (from a use point, maybe not from a physical size issue). If a heatpump version has resistance backup, on some uses, it may not be any more efficient than a typical electric WH.
  2. #17
    DIY Member bmcgin's Avatar
    Apr 2010
    PC Beach, FL
    Only the Steibel Eltron uses a smaller resistance heating element for highest efficiency...
    It is the only one that can be installed with a 15 amp circuit the others need a 30 amp circuit....
    GE: 30 amp, Smith: 25 amp, Rheem: 22 amp, Steibel: 15 amp
    Energy Factor:
    GE: 2.35, Smith: 2.4, Rheem: 2.0, Steibel: 2.5
    So the Steibel will draw less amps and makes the best use of energy. Looks like a very good product.
    Only problem is the size, it’s 26” round. I have space for 24”. So unless I want to start revamping ductborad, it’s not going to fit.
    My current water heater is actually a 40 gal and we’ve never run out of HW, so a 50 gal should be sufficient. 99.9% of the time this water heater supplies 1 full bath (for a 4 yr old), kitchen sink and dishwasher.
  3. #18
    Dec 2007
    Actually the Stiebel Eltron Accelera 300 draws a maximum of 9.16 amps.
    What you should also look at is the 1st hour delivery...
    Your present unit is probably in the mid 50 gallon range....
    Stiebel Eltron Accelera 300: 78 gallons
    GE GeoSpring Hybrid: 63 gallons
    Rheem/Ruud Hybrid: 67 gallons
    AO Smith Voltex: 70 gallons
    But the AO Smith Voltex is also an 80 gallon tank like the Stiebel Eltron Accelera 300 so there might be dimensional issues with that as well.
    The Stiebel Eltron Accelera 300 has a single 1750 watt element.
    The AO Smith Voltex upper element is a 4,500-watt element and the lower element is a 2,000-watt element.
    The others all use 2-4500 watt elements...
  1. Combining an electric Tank with electric Tankless
    By Dkrasko in forum Tankless Water Heater Forum
    Last Post: 03-27-2014, 08:24 AM
  2. Electric Tankless Help!
    By schinks in forum Tankless Water Heater Forum
    Last Post: 06-27-2010, 07:38 AM
  3. electric heat pump in cold climate?
    By flatlander dave in forum HVAC Heating & Cooling
    Last Post: 06-13-2009, 08:08 AM
  4. Combining an electric Tank with electric Tankless
    By Dkrasko in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-28-2008, 03:14 PM
  5. Oil heat -- efficient temps... and electric heat in one room?
    By Pickngrin in forum HVAC Heating & Cooling
    Last Post: 10-07-2008, 04:34 PM
