Results 1 to 6 of 6
Thread: Anybody object to this pass/fail specification for city water delivery?
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    Default Anybody object to this pass/fail specification for city water delivery?
    Based on [more or less] responses from two water utilities,
    an adequate city water supply for a single family house can deliver
    more than 5 GPM and
    between 20 & 80 PSI and
    PSI x GPM should be more than 400.
    This last line takes about 1/4 hp to accomplish and is my addition to this benchmark.
    And WHAT is the relevence of PSI x GPM being 400? That does NOT create ANY useful measurement. IT is like a toilet's 1.6 gpf x 6 lpf equals approximately 10.
    Plumber jimbo's Avatar
    Why do you need to write a spec for the city? They will deliver what they feel like. Many places, they will deliver much higher than 80 psi, and rely on you to provide a regulator.
    The minimum gpm is based on meter size. A 1/2" or 5/8" meter will deliver 5 gpm. If you want more gpm, you have to PAY for a larger meter. And the city will deliver whatever volume you choose to pay for.
    Aug 2008
    MD
    Sorry for the misleading title.
    It's a spec for OPs to judge if their city water supply is substandard or if a pipe is partially clogged. That question/complaint comes up a lot.
    The static pressure and max flow rate is not hard to get, but the 400 is an approximation to a pump curve between these two endpoints. It corresponds to about a 1/4 to 1/2 hp pump.
    If your house can maintain 40 PSI while delivering 16 GPM you're doing well. 5 GPM @ 5 PSI is terrible.
    Here's what two WaCos said
    Per the Department of Health Waterworks Regulations the
    minimum allowable delivery pressure is 20 psi.
    . . .our targeted range for delivery pressure is 40 to 80 psi. Flow rates are a function
    of demand but a standard size residential meter (5/8") has a maximum
    capacity of about 20 gpm.
    and
    We don't use a benchmark. The pressure range is between 40 and 80lbs. if
    below 40 a booster pump is need and above 80 a pressure reducing valve.
    The usual calculation is gpm AT a specific psi, NOT gpm TIMES psi, (which does not yield any kind of useful number).
    Aug 2008
    MD
    GPM at a specific PSI or feet of head implies horsepower.
    hp = (head x GPM)/3956 for water.
    If you wanted to simulate city water and you lived next to a lake and your house was a few inches above the lake's surface, a 1/2 hp pump at any depth would probably work.
    I think the WaCos don't use this because almost always just a static pressure and working water meter guarantees a usable water supply. Only when there is a problem do they use instruments and charts.
  1. Need Sta-Rite control, capacitor specification.
    By James Duca in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-17-2010, 05:54 AM
  2. symmonds temprol will not pass water
    By jaaron in forum Shower & bathtub Forum & Blog
    Last Post: 09-25-2009, 11:57 AM
  3. This box fail to pass inspection
    By Ford2001 in forum Electrical Forum discussion & Blog
    Last Post: 09-20-2009, 06:54 PM
  4. Sparodic water delivery, submersible
    By ratkillingdog in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-26-2009, 08:00 PM
  5. Question about hot water delivery system?
    By jk60 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-31-2006, 08:44 AM
