Results 1 to 6 of 6
Thread: adjusting the shower head angle
    DIY Member econguy's Avatar
    Apr 2007
    Massachusetts
    Default adjusting the shower head angle
    Question regarding shower head...even when it's angled as low as possible, it's still aimed too high.
    Is there a connector of some type that goes between the shower arm and shower head that would allow me to angle the water spray lower?
    Will
    You might need to replace the shower arm with one that has more of a bend in it or buy a new showerhead.
    Buy a shower arm that points straight down, and then use the head's adjustment to turn it upwards.
    Danze 9" adjustable shower arm
    Product # D481146
    This is what I've used. When James was in high school, he was 6'4", and Taylor was 4.
    If you get one of those, be sure it has "teeth" at the swivels to hold the arm in position. It is almost impossible to tighten "friction" swivels tight enough to keep them from sagging.
    One who lurks Basement_Lurker's Avatar
    Jun 2007
    Victoria, BC
    Or you could replace your showerhead all together with a slidebar unit.
    Broken promises don't upset me. I just think, why did they believe me? -Jack Handy
    www.blackbirdkitchenandbath.com
  1. More Shower Head Angle
    By ivode in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-09-2009, 05:12 PM
  2. Neo-Angle Shower Door
    By rachel.whitehead in forum Shower & bathtub Forum & Blog
    Last Post: 10-24-2007, 12:08 PM
  3. Angle Shower head question.
    By OldPete in forum Shower & bathtub Forum & Blog
    Last Post: 01-16-2007, 07:42 AM
  4. Adjusting water temp on a Moen shower
    By Eeep in forum Shower & bathtub Forum & Blog
    Last Post: 02-13-2006, 06:00 PM
  5. Fastening shower neo angle shower doors to fiberglass
    By tf in forum Shower & bathtub Forum & Blog
    Last Post: 09-25-2004, 04:16 AM
