Thread: Best Cleaner/brush for Toto Sanagloss?
    DIY Junior Member cwooden82's Avatar
    Oct 2010
    Keizer, OR
    Default Best Cleaner/brush for Toto Sanagloss?
    Hi - after much reading have decided to buy a Toto Drake II to replace my ancient toilet (house built in '55, I think it's the original - has 4 bolts instead of 2) At first was going to cheap out - $ being pretty tight- and get a cadet or a Niagara. They had both of these installed in the ladies rm at my local plumbing shop, they let me stay in there and do flush tests. Not being totally happy with the results, ( they both failed the pepper test ) decided to get out the card and go for the double cyclone flush with SG. I want to make sure to take good care of the finish - what do you recommend for cleaning inside/outside?
    The AS Cadet would probably work OK as long as it wasn't defective. Pros like Terry and Redwood report many factory defects. The Niagara is really bad news, so it's good you stayed away from that one. Two of the four bolts on the old one go into the floor. The other two into the flange. You are spending a bit more for the Drake II, but you are getting a better toilet. I'm not sure what to use, but I do not you want to stay away from abrasives that will damage the Sanagloss, and are totally unnecessary on the exterior anyway. Your dealer should be able to recommend a good product and may even sell something. Hang around the forum, there will likely be some good suggestions.
    Engineer Furd's Avatar
    Jul 2007
    Wet side of Washington State
    I have had a Toto Carlysle with Sani-glos for about ten years. I use Simple Green (diluted about five to one) with a plastic bowl brush (not a brush with a twisted wire holding the bristles) for general cleaning. I also disinfect with about a half-to-full cup of cheap bleach swished around and left for ten minutes maximum. Flush two or three times after the bleach treatment. About once a month pour some bleach through the overflow tube in the tank to disinfect the rim passages and holes. Follow this with two or three flushings after ten minutes.
    Oct 2010
    Keizer, OR
    The Cadet didn't have a good bowl wash, left pepper on the bowl even after a few flushes - read about some fixes having to do with reaming the holes out with a clothes hanger - no thanks. Don't feel I should have to fix a brand new fixture. The Niagara cleaned the bowl but didn't get rid of all the pepper - there was still some swirling around in the water after a few flushes.
    Furd - thanks for tips.
  1. Toto Promenade - Eco or no? Sanagloss or no?
    By single_digit in forum Toilet Forum discussions
    Last Post: 03-09-2010, 09:37 AM
  2. PC-Cleaner registry cleaner to fix your errors
    By systemcleaner in forum Computers and Stuff
    Last Post: 03-03-2007, 07:03 AM
  3. Toto SANAGLOSS more info please.
    By the engineer in forum Toilet Forum discussions
    Last Post: 09-28-2005, 06:54 PM
  4. Toto sinks w/sanagloss
    By decisions, decisions! in forum Remodel Forum & Blog
    Last Post: 09-08-2005, 04:12 PM
  5. Toto - SanaGloss
    By Craftycas in forum Toilet Forum discussions
    Last Post: 02-01-2005, 09:52 AM
