Results 1 to 7 of 7
Thread: Is there a plumbers dye?
    DIY Junior Member DIYourselfer's Avatar
    Dec 2008
    New York
    Default Is there a plumbers dye?
    Trying to find a leak in bathroom. Is there a dye that the pros use that won't stain a tub? If I use a dye in the tub water then I will know when I see the dyed water on the unfinished ceiling below that it is probably the drain, not the pipes or mixing valve.
    Thanks!!!
    One who lurks Basement_Lurker's Avatar
    Jun 2007
    Victoria, BC
    Food colouring will do fine.
    Broken promises don't upset me. I just think, why did they believe me? -Jack Handy
    www.blackbirdkitchenandbath.com
    If the leak stops, then it is NOT the pipes. There are easier ways to isolate whether it is the valve or drain, and a plumber would know how to do it.
    In the Trades SacCity's Avatar
    Mar 2011
    Sacramento, CA
    To check for leaks in toilets, specifically flapper valves I generally use food coloring.
    I would be hesitant to use dies in other locations.
    Michael
    Feb 2011
    NW Ontario, Canada
    I remember many years ago, the septic field police were going around to homes and flushing a packet of dye down the toilet. Then they would walk around the property looking for the dye to break to the surface or enter a stream.
    Mar 2011
    Sacramento, CA
    Marina's do the same thing with boats, throw a die packet into the holding tank so they can fine anyone who pumps overboard!
    Jan 2008
    Plumber's dye is what they use to dye the Chicago River green on St. Patrick's Day.
    http://www.greenchicagoriver.com/story.html
  1. For Plumbers:
    By organic_smallhome in forum Toilet Forum discussions
    Last Post: 09-03-2009, 07:07 PM
  2. Plumbers putty use
    By jzbeaver in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-09-2009, 06:40 AM
  3. pages for plumbers
    By Terry in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-26-2008, 03:28 PM
  4. Danco Plumbers Waterproof Grease vs Danco Plumbers Silicone Grease
    By RochNY in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-11-2007, 06:19 PM
  5. For plumbers ,please
    By toolaholic in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-16-2006, 09:31 PM
