Thread: newbie question about 11" rough in
    DIY Junior Member danglus's Avatar
    Oct 2009
    atlanta, ga
    Default newbie question about 11" rough in
    Terry,
    I'm a big fan of your site and find it to be my go to site for anything plumbing related.
    I have just finished contructing a previously roughed in bathroom. I was planning on buying an aquia II toilet 10", but i just went to double check the rough in measurements now that the tile is installed. I have not yet installed a flange but my drain stub is exactly 11" from wall to center of stub.
    Because the drain line is installed against a joist, i couldnt have moved it any more and i dont have access for an offset flange (i have to use a drop in flange). Is it possible to use a standard aquia II 12" toilet or do have to use a 10"
    Thanks for your advice,
    Danglus
    Oct 2009
    atlanta, ga
    Default another comment to add
    i have read on this site that the ultramax has extra space behind it and might fit, is this true for the Aquia also?? looks like i might have to get the ultramax and will probably get the eco sanigloss model.
    The Aquia III spec sheet http://admin.totousa.com/Product%20D...MF,%20V.05.pdf shows 1/2" behind it on a standard 12" rough-in, so with 11", I don't think it would fit. Toto has spec sheets for all of its toilets (and the rest of the stuff they make) on their website.
    Oct 2009
    atlanta, ga
    After reading all of the reviews and recommendations..i went ahead and ordered an EcoDrake....and will hope for the best during the install!
  1. Toto Ultramax 12" rough-in, but sits 2" out from the wall
    By pottynovice in forum Toilet Forum discussions
    Last Post: 10-24-2010, 02:18 PM
  2. Replies: 5
    Last Post: 09-18-2009, 06:58 PM
  3. 11" Rough In Question
    By yervesjdunne in forum Toilet Forum discussions
    Last Post: 07-12-2009, 11:45 PM
  4. 10" rough-in question
    By Kalaran in forum Toilet Forum discussions
    Last Post: 06-19-2009, 09:53 PM
  5. Newbie from Utah needs some advice with 4" recessed lighting
    By utahpaul in forum Electrical Forum discussion & Blog
    Last Post: 02-04-2008, 03:58 AM
