Results 1 to 5 of 5
Thread: minimum size for washing machine fixture
    DIY Junior Member mmmm's Avatar
    Apr 2010
    British Columbia, Canada
    Default minimum size for washing machine fixture
    Hi,
    I am in a older house with 2x4 construction. We are relocating our washer. I searched and found that the minimum size for the stand pipe is 1 1/2" for Canada. Can I have a 2" stand pipe going into 1 1/2" p trap? The length of the stand pipe is 29".
    Mike
    Jun 2009
    Canada
    What would be the point?
    The only thing that will come from downsizing as you go downstream is problems.
    In the Trades Jerome2877's Avatar
    Aug 2009
    BC
    No you cannot do that by code.
    Jun 2009
    Penticton, BC
    Quote Originally Posted by Jerome2877 View Post
    Not true at all.
    The NPC of Canada doesn't say much about what you can do with a fixture outlet pipe, but only what you can do with a trap and what's downstream of a trap.
    Lots of people put 2" stand pipes in when they remodel because it gives you a bit more volume before the washer backs up if you have old, slow draining pipes.
    I've seen it plenty of times and it's perfectly acceptable on a retro-fit.
    Yakima WA
    Code issues aside, there are a couple of problems you may encounter. Newer washing machines empty water very rapidly and a 1-1/2" drain is too small to handle it. As noted in a previous answer, the 2" standpipe will give you a small amount of extra space, but may or may not be enough. A pretty basic principle in drain plumbing is that you never reduce the size going away from the fixture. It's rather like a funnel with a large top and small outlet. You can pour a bunch of liquid in the top, but it will empty slowly through the small outlet. Keep pouring water in the top, and it will overflow. If your drain pipes are old galvanized pipes, they also can be half clogged with crud which effectively makes the pipe even smaller.
  1. Codes minimum size and opinion
    By willl in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-03-2008, 06:10 AM
  2. Minimum pipe size for a toilet vent?
    By lahabra in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-23-2007, 02:38 PM
  3. Wire Size / Fixture Attachment
    By OscarG in forum Electrical Forum discussion & Blog
    Last Post: 08-21-2007, 01:48 PM
  4. water supply fixture units & pipe size
    By richh in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-17-2006, 07:55 AM
  5. What size stack for a washing machine?
    By cwolters in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-07-2005, 04:56 PM
