Thread: Installing Glass Shower Door and Fixed Panel
    DIY Junior Member newmex999's Avatar
    Dec 2009
    nm
    Default Installing Glass Shower Door and Fixed Panel
    I will be installing a 30" hinged shower door attached to the wall and a 30" fixed panel across a 60 inch straight shower opening. The unit is frameless, so the fixed panel sits in a u channel on the bottom and the wall.
    Any tips/tricks on getting the door and fixed panel installed & lined up?
    One reservation I have is that the instructions have me drilling 1 1/4" holes to anchor the u-channel to the shower curb. I am pretty sure if I drill this deep I will be piercing the rubber membrane underneath!
    Also if I don't hit a stud when I mount the door hinges is it acceptable to drill and use plastic anchors with the 2" screws (I have 1/4" thick limestone 12x12 tiles mounted over 1/2" hardie board)
    Dec 2009
    nm
    Default Stump the Pros?
    Did my questions stump the pros? I hope not, I know you guys can help me here.
    Check out www.johnbridge.com. I think you'll get more exposure to tiling pros there. Lots of good plumbers, and some general contractors and electricians here, but not too many tiling pros...John Bridge's site is dedicated to tiling things.
  1. Installing Kohler sliding glass shower door:
    By oldberkeley in forum Shower & bathtub Forum & Blog
    Last Post: 04-08-2010, 10:12 AM
  2. Best way to reattach glass door unit to fiberglass shower wall?
    By nightowl in forum Shower & bathtub Forum & Blog
    Last Post: 01-13-2009, 06:04 PM
  3. Frameless shower door and Glass Block install
    By crosby1 in forum Shower & bathtub Forum & Blog
    Last Post: 02-07-2008, 05:36 PM
  4. Patio Door, Low E glass vs Clear glass
    By thegallery in forum Remodel Forum & Blog
    Last Post: 11-28-2007, 04:33 AM
  5. Door / Glass Block Combination
    By gsfromc in forum Remodel Forum & Blog
    Last Post: 01-07-2007, 09:28 AM
