Results 1 to 7 of 7
Thread: Single to double vanity - Illinois (a new version)
    DIY Junior Member Savedsol's Avatar
    Apr 2013
    Chicago burbs
    Default Single to double vanity - Illinois (a new version)
    I'm also converting a single to double vanity in Illinois (I can hear the groans ). My situation is bit different, we had a right hand sink and after opening the wall all of the plumbing is coming off the right side so I can't use Terry's famous diagram. I'm not too worried about the water supply it's tapping into that giant stack! How do you add another Wye into that?
    Much help is appreciated. Unrelated but based on everyone's recommendation, I've ordered a Toto Drake II for the ladies of my house. I'm hoping it can flush Coke cans!
    (in the pic below I just illustrated the Hot/Cold and where the copper terminates)
    Nov 2008
    Chicago, IL
    Is both bowls going to be in the same room, and are they both going to be to the left of the stack? Or is one going to be left and the other right of the stack?
    Nov 2008
    Chicago, IL
    Also another note, since you are doing more than a simple repair, you should get a permit from your town/city, and while there you can ask the plumbing inspector the acceptable way to plumb in a double vanity.
    Nov 2008
    Chicago, IL
    This would be the proper way to plumb a double vanity, sorry about the crude drawings but I hope you see that there is a revent and both lines tie into the revent bar. The way I drawn will meet the letter of the plumbing code and no inspector would fail it.
    Apr 2013
    Chicago burbs
    Thank you SewerRatz. The sink on the right will stay on the right where the current plumbing is for feed/return. The left sink will go approx where you've drawn it. The only thing I'd point out is the 1 1/2" PVC Wye is just proud of the the 2x4 which I imagined would make for trouble T'ing off of it as you've drawn. I'll try to grab a pic and post it shortly. But I'm guessing you're pic is removing/replacing/repositioning the current Wye.
    Nov 2008
    Chicago, IL
    You have that correct, it is removing the current fitting lowering it a little and installing a second wye upside down above the spill level of the sinks for the revent.
    Apr 2013
    Chicago burbs
    Excellent. I sent you a PM too SewerRatz.
  1. Converting single sink vanity to double vanity
    By xceebeex in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-28-2011, 09:22 AM
  2. Single to Double vanity
    By mfl in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-30-2011, 05:20 PM
  3. Single to double vanity - better way? Illinois
    By john-ee in forum Illinois Plumbing Code Questions
    Last Post: 10-16-2010, 04:51 PM
  4. another Single Vanity to Double Vanity thread, IPC
    By tekmassa in forum IPC Plumbing Code Questions
    Last Post: 06-05-2010, 01:30 PM
  5. another Single Vanity to Double Vanity thread, IPC
    By tekmassa in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
