Results 1 to 5 of 5
Thread: Hard seat and soft seat
    General Contractor dx's Avatar
    Jul 2005
    Michigan
    Default Hard seat and soft seat
    What exactly is a hard/soft seat valve, what purpose does each serve, and where is one used vs. the other?
    http://store.webstonevalves.com/defa...itemcode=10542
    Plumber jimbo's Avatar
    Hard seat means metal to metal contact. A soft seat would have a seating surface with a rubber gasket, or maybe a teflon ring, or such.
    When it comes to check valves, a soft seat will not make as much noise when it closes. The hard metal to metal contact of the hard seat can cause be quite loud, especially if there is a lot of back pressure "slamming " it shut. The hard contact can also cause it to "rebound" creating a chattering noise.
    Jul 2005
    Michigan
    Thanks guys. Related question: some swing checks are labeled "for horizontal installation only". I do understand why. But why aren't all of them labeled that way? Can some of them be installed vertical or is it just that some manufacturers fail to label them properly?
    I cannot imagine why they would be labled that way, since gravity and the weight of the liquid would close them in a vertical orientation. When they are installed horizontally, some have a label to show which side should be on top, because the hinge location is not obvious.
  1. Soft Close seat design
    By Hapuna in forum Toilet Forum discussions
    Last Post: 11-04-2009, 06:01 PM
  2. Soft close seat: Ugly sticker hard to remove, upgrade to a Washlet
    By intravenous in forum Toilet Forum discussions
    Last Post: 12-02-2008, 02:45 PM
  3. Aquia II Soft Close Seat Squeaks!
    By Shellbank in forum Toilet Forum discussions
    Last Post: 10-15-2008, 03:28 AM
  4. Toto soft close seat
    By chaoster in forum Toilet Forum discussions
    Last Post: 10-05-2006, 11:18 AM
  5. TOTO ZOE Soft close toilet seat
    By jw1 in forum Toilet Forum discussions
    Last Post: 05-27-2006, 06:07 PM
