Yes, a resonance effect. Maybe the prv manufacturer is gambling on very few people having unsupported pipe lengths that are just right to cause this.I personally think that in the course of the PRV doing its job there is going to be some resonance induced. The frequency will vary with the flow rate but it is there. If the length of the unsupported pipe is at the tuned length for that frequency the pipes will sing! The hangers now have the pipe length off tune and there is no noise.
Find as many ways as you can to change the pitch or stop the noise or make the noise worse.the noise is back.
i just dont understand why the noise would stop when he increased the PRV water pressure.
One possibility is that with high GPM a high input/output pressure differential implies that the PRV has to absorb more power, since the power of moving water is proportional to GPM x PSI.
He reduced the differential and so reduced the energy that the PRV had to absorb.
Just to confirm, can you post specs to your PRV? I'm looking for max differential pressure vs. GPM. I'm guessing the product of the two should be a constant, depending on the design of the PRV.
If this is so, then I guess if the city increases their pressure your noise might return. And, at the old pressure setting there should have been some low value of GPM that gave no noise.
This spec. request should have been my first question.
Things won't explode! But, if the PRV IS working properly, the internal house pressure can rise quite high after a lot of hot water use as it gets reheated...it must expand - that's just a law of nature! Now, without a PRV or a checkvalve in the house (called an open system), that water volume just pushes back into the supply. A PRV closes off that path (and becomes a closed system - or maybe better called a one-way system). Some PRV's have an internal bypass. If the one you have, when the house pressure rises to match the incoming supply pressure, it will allow water back, so while it will rise, it will peak at the supply pressure. Now, the actual volume of that expanded water depends on how cold it was coming in (denser) and how hot your WH is set (less dense - ie., expanded) and the capacity of the WH tank. It generally isn't that much, but any just raises the pressure - expands the supply hoses to things, and stresses everything. But, the longer the stress, the more likely something will give way. the more common things are washing machine hoses; leaking toilet fill valves, or a leaky faucet.
Get a water pressure gauge. Screw it on where it will fit (it often comes with a hose type connector, but you can use adapters to put in anywhere). Get one that has a tattle-tale hand (max reading). Leave it attached overnight and after you've done your largest hot water use (often in the morning). Look at the static and max pressure. Without an expansion tank on a closed system, if everything is working properly, the pressure WILL rise after the WH reheats water. The more hot water used, the larger the volume increase. If it doesn't rise, at least to the incoming water pressure, something isn't working properly. An expansion tank is cheap protection for all of the plumbing in the house.
They aren't all that hard to install. Cut the cold water supply after the shutoff to the WH, put in a T, solder a threaded coupling on the leg of the T, screw in the tank, support it properly, and you're done. Well, you should first adjust the precharge of the tank. It has a valve just like a tire. Generally they come with about 40psi from the factory, but it is best to adjust it to the static water pressure out of the prv. You need to do this before you connect it to the water supply, otherwise, you'll just read the water pressure, regardless of the air pressure in the thing (unless you set the air pressure higher than the incoming water pressure).
Most of the townships on the outskirts of the city of pgh now require expansion tanks.
Even if you are city, I would add one.
