Results 1 to 2 of 2
Thread: No Air In Lower Floor Vents
    DIY Junior Member shezzy's Avatar
    Oct 2010
    Baltimore MD
    Default No Air In Lower Floor Vents
    I found out that air is not blowing in the vents in the lower floor. A technician came to check the system and said that the system is fine, but may be a fire damper is shut down somewhere. He was too lazy to help me out. Where do I find the fire damper, and how do I get it re-opened?
    Homeowner Thatguy's Avatar
    Aug 2008
    MD
    Quote Originally Posted by shezzy View Post
    Find where the lower vent ductwork comes off a common feeder. The damper control may just be a square shaft with a handle coming out of the side of your duct.
    http://www.google.com/images?client=...w=1100&bih=563
    http://www.google.com/images?client=...w=1100&bih=559
  1. debris blowing out through floor vents
    By kramersfolly in forum HVAC Heating & Cooling
    Last Post: 03-17-2009, 06:07 AM
  2. Flange slightly lower than finished floor
    By gramps in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-07-2009, 03:15 PM
  3. Tap into 2in DWV to add sink drain on lower floor
    By DWClark in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-29-2005, 04:07 PM
  4. Lower Sink Part 2
    By frank1138 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-04-2004, 02:50 PM
  5. New sink is lower...need to lower drain?
    By plumbbob in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-07-2004, 02:23 PM
